Page 1 of 2
Impact XT Copy External Files possible?
Posted: Mon Jun 04, 2018 8:49 am
by sangamc
I store all my samples on an external drive because I have a laptop.
When I'm done making a song, I usually copy external files so that everything is in the correct folder and I can work on my songs when I am travelling.
Started using the new impact XT and sample one XT instead of NI Battery and Polyplex. I was super excited until I was away from home and none of my songs had their drum samples. :?
I can not for the life of me figure out how to collect all and save with samples in Impact or Sample 1.
I do not want to make soundsets. I don't have the space to take them with me (and its a chore). I also don't want to bounce drums to audio every time I'm jamming or making songs because I have a laptop and single samples for each drum sound is way less space that 3 to 4 min wav files.
PLEASE HELP!! gonna make me run back to Live 10
Re: Impact XT Copy External Files possible?
Posted: Mon Jun 04, 2018 9:25 am
by matthewgorman
With the song open, go to File, Copy External Files.
You can also with song open, go to the pool tab in the browser, rt click, and copy external there. There is also a preference in options that will have S1 ask to save external files on save or close.
Posted: Mon Jun 04, 2018 10:07 am
by sangamc
That is where the problem is.
When I do that from the song menu or the browser. It does not copy the external file used in Sample One or the Drum Kit files used in impact XT.
I just get the message: "There are no external files"
The file is not in the pool either. I've tried saving the impact XT as a preset but that doesn't do it either.
Posted: Mon Jun 04, 2018 10:22 am
by matthewgorman
So it sounds like you are using the samples included in Studio One? If that's the case, then maybe those soundsets are not installed on PC #2?
Posted: Mon Jun 04, 2018 10:47 am
by sangamc
NO, these are samples I've collected on my own (mostly from splice).
They are stored on an external hard drive.
When I collect all and save, then take my laptop on the road. The samples that are used in impact and sample one are not collected within the song folder. They remain on my external hard drive at home.
That is the main issue. How do I collect all and save when I put samples into Impact or sample One.
Like I mention earlier. I do not want to drag soundsets along since they take up space. In fact I install S1 with 0% of the additional content. I dont need or want it. Just the relevant parts of my own audio saved with the song.
Posted: Mon Jun 04, 2018 10:48 am
by sangamc
Forgot to add, there is no 2nd PC, just the one laptop and any audio that is on audio channels seems to collect and save with no problem.
Posted: Mon Jun 04, 2018 11:40 am
by robertgray3
I think the changes to how Impact XT stores samples may have made it more difficult to encapsulate your samples within a project.
I haven’t dug into it too much myself but check this thread: viewtopic.php?f=151&t=30379&p=173654&hilit=Impact#p173654
Posted: Mon Jun 04, 2018 11:48 am
by sangamc
Thanks for the reply. Looks like this can not be addressed on my own :(.
I'll take it into account going forward and hope it gets addressed in a subsequent update.
Posted: Mon Jun 04, 2018 3:11 pm
by robertgray3
Found a workaround for now that might work for you.
- Export to a Sampler file
- Import the same Sampler file from your browser
- Save the project
- It should prompt you here to save the sampler file in your directory.
I didn't extensively test it- I tried it once and it worked, then I tried it again and it gave me a message about the "package file not matching the samples" and loaded an empty preset. And the third time I tried it it kept asking me to import the soundx file every single time it saved. Hopefully it works better for you.
Hoping this gets to be a bit more elegant and singular (at least in feel/application) in the future. We now have four ways to store and recall an Impact Kit (Preset, Instrument+FX, Sampler File, Import Song Data), each with its own upsides, downsides, and quirks.
Posted: Tue Jun 05, 2018 9:09 am
by sangamc
robertgray3 wroteFound a workaround for now that might work for you.
- Save the project
:punk: :punk: :punk:
Not elegant solution by a long shot, but this is exactly what I was looking for. It seems like they had the right idea, but just did not execute or simply forgot.
The quirkiness of the .song referencing the original soundx files even thought there are copies in the actual song folder can be overcome. Also if a pad is created by selecting a sample from a folder, all samples in that folder become part of the soundx, but I'll live with that when I am on the road. Since the final soundx 10.6MB which is very good for my laptop HDD.
This post is solved.
THANKS!
Posted: Tue Jun 05, 2018 9:29 am
by PreAl
sangamc wroteStarted using the new impact XT and sample one XT instead of NI Battery and Polyplex.
Just a side question.
Why use Impact over battery? I have Battery version 4 and it appears superior over Impact in every way. The only thing it does not do is open soundsets (and Personus make it purposely difficult to extract the samples from that format imho).
Posted: Tue Jun 05, 2018 9:38 am
by robertgray3
For me personally, it's a joy to use and integration with Studio One (drag and drop import, pattern editor, export) and not having to deal with Battery 4's absurd user interface push it over the edge.
It's probably good that people switch over, that means the little things such as this one about the global and per song file storage will be noticed and refined.
Posted: Tue Jun 05, 2018 9:47 am
by PreAl
Apart from soundsets I don't see any less integration with Battery than I do with Impact. I can do all of those things you state I believe. Battery has a larger feature set, I didn't have any issues with the UI myself, no less complicated than other plugins.
Posted: Tue Jun 05, 2018 10:58 am
by robertgray3
Can you grab a folder of samples drag them over hole shift and have them automatically mapped in ascending order?
Posted: Tue Jun 05, 2018 12:22 pm
by PreAl
robertgray3 wroteCan you grab a folder of samples drag them over hole shift and have them automatically mapped in ascending order?
I can save a template for the mappings and recall what I want by default every time (or choose another template).
I can drag samples in via Studio One browser, but why would I. I would naturally go through the Battery browser. I can drag, add favs, import into library.
Better still, if I use the plugin away from Studio One and then nothing changes. I can use any plugin host and I can also use Battery Standalone. I'm not locked in to just one DAW.
Posted: Tue Jun 05, 2018 1:13 pm
by sangamc
CPU overhead with all NI products has me using them sparingly for my day to day beat making. Even the new TRK-01 hogs 25% of my CPU which is not worth it for drum sounds before I've even started bussing or adding FX.
DAW integration is next. Nothing is more efficient than well made stock plugins. Especially when all they need to do is basic tasks like trigger drum samples
I like using the stock devices in all my beat making templates. Before Impact XT I was in Live 10 using drumracks while Presonus brought things up to date.
It's just faster for my workflow.
Posted: Tue Jun 05, 2018 1:20 pm
by sangamc
PreAl wroteBetter still, if I use the plugin away from Studio One and then nothing changes. I can use any plugin host and I can also use Battery Standalone. I'm not locked in to just one DAW.
This is my fav part about NI products. Its why I have so many of them! But sadly I just don't have the horse power to use them all together. :|
Posted: Tue Jun 05, 2018 4:06 pm
by graytermedia
I've started using Impact XT over Maschine for the same reasons as mentioned above. Maschine is a PITA to use with almost any DAW (except for Ableton Live). I've begun pulling the drum samples from my Maschine expansion libraries into Impact.
Loads easier to work with.
The only thing I'm missing are Maschine's built in effects, but the Plugin-Alliance transient shaper stuff (and my other 3rd party effects) are better anyway.
tg
Posted: Tue Jun 05, 2018 4:13 pm
by PreAl
I agree Maschine is well overboard (poor process overhead) and regardless it's sequencer isn't that great.
It's a sledgehammer to crack and nut, sadly the sledgehammer is only suitable for a certain type of nut and too heavy to lift.
Battery on the other hand is a completely different beast. A much lighter affair and is similar to Impact. It's probably going to have better cross compatibility with Maschine being a NI product.
Posted: Tue Jun 05, 2018 5:10 pm
by graytermedia
I'm a Komplete user and have programmed drums with Battery since version 2. While I agree with the DAW hopping aspect - a habit I'm trying to break with S1v4 - I find Impact easier to use. I think its strength lies in its lack of features. I don't really need the built in effects because I have better 3rd party stuff.
tg
