You are correct. Apologies. Now I'll have to figure out why I used to see some
impact audio sources listed in the pool in v3 but don't now. See the image below from v3. It's always been that way with
Impact, where the samples listed that way. Not sure if it not doing that now in v4 is a bug or by design.
- impact sample.png (4.91 KiB) Viewed 7945 times
And again, apologies. I assumed (incorrectly it appears) that since you've been around since 2015 that you would seen that before in v2, 3, etc if you'd ever used
Impact before, but it doesn't appear to do the same in v4.
Interestingly enough, loading that v3 test song into V4 does load and also list that sample in the pool but the file is listed in the "unused" folder, and dropping in new files the new ones don't list anywhere.
Anyway, sorry for the longish post. I tend to always dig into stuff before asking why, just to see if behaviors may have changed or something and they appear to have changed in this case.
