I use a mid 2014 MacBook Pro with a quad core Intel 2.5 GHz and a really basic BOSS Interface. It doesn’t seem to support very low block sizes and my CPU gets taxed pretty heavily that low anyway. I’d love to use lower buffers in general for lower latency when playing and recording virtual instruments since I dislike going into my menu to switch buffers and Low Latency Monitoring for Instruments has a lot of annoying kinks.
At the risk of asking too general a question, would I be better served by getting a Quantum and hooking it up over Thunderbolt or should I wait until I assemble a better computer? Guess I’m wondering if that CPU could get me low latency if I plugged in a Quantum. I know some guys here use MacBook Pros so was hoping someone had a similar computer and could tell me how it fares with a higher end interface.
Mac OS X Mojave 10.14
Mac Pro (Late 2013)
3 GHz 8-Core Intel Xeon E5
32 GB 1066 MHz DDR3
Dual AMD FirePro D500 3072 MB
by jpettit on Sat May 26, 2018 12:06 am
Quantums are real fast.
1-2 ms RTL
But why are you not using drop out protections?
by robertgray3 on Sat May 26, 2018 8:10 am
I use Max dropout protection and it helps the CPU load, should have mentioned that.
But from my testing my BOSS interface just doesn’t support low block sizes.
Sounds like an interface upgrade would be good.
Mac Pro (Late 2013)
32 GB 1066 MHz DDR3
by jpettit on Sat May 26, 2018 8:18 am
You should list your latency and use case.
Input device type of recording etc.
There are many less expensive options.
by Jose7822 on Sat May 26, 2018 10:53 am
I’d say the interface is what needs to be upgraded in your case. Your CPU should be good, but obviously the faster the clock cycles, the better your performance will be in terms of latency. So eventually a computer upgrade would get you all the way there. But the interface upgrade should give you the most bang for your buck, especially if you go with thunderbolt or a USB interface from a company such as RME. In my experience RME drivers are second to none. Not only are they super stable, but they give amazing latency especially when considering the types of low latency achievable with their USB interfaces.
You’ll need to provide more info regarding what you need in an interface, as well as a budget, in order to get targeted recommendations that will be helpful.
Gigabyte X99 Designare EX | Intel Core i7 6800K (OC'ed to 3.7 GHz) | 64GB of Corsair Dominator Platinum (3333 MHz) | EVGA GTX 1070 FTW | Corsair H115i Water Cooler | Be Quiet! Dark Power Pro 1200 Watt PSU | Windows 10 Pro 64 bit | Studio One v3.5 | Lynx Aurora (n) 8TB | UAD 2 Octo | UAD 2 Quad
Users browsing this forum: lixisoft, markbirmingham1, nikolaospitloglou and 20 guests
