I'm having trouble getting my Roland keyboard controller to work in Studio One. I also have Sonar Platinum and it works in Sonar. I also am able to use Rapture Pro in stand alone and it works with that as well. I had to add the keyboard manually under external devices in Studio One as it was not available in the product list. It shows in the deep down lists for resource from and send to. I have Receive From: A-PRO MIDI IN, and Send To: A-PRO. This is the path that works with everything else. I've attempted to use the keyboard with Mai Tai, EZkeys and Rapture Session and not of them will communicate with the keyboard in Studio One. I'm using Studio One 3.5 and I'm running Windows 7. Any help would be greatly appreciated.
Sent from my SM-G930P using Tapatalk |
I've already been through this, follow this thread carefully beginning to end. A few screenshots may help you as well. Most setup areas are covered (maybe not in the right order).
viewtopic.php?f=151&t=27865
Receive from MIDI IN might be wrong. Midi IN means you are sending to it maybe. What other options are there for Receive FROM.
When you play do you see activity in the little midi icon down below. That will tell you if you are in fact receiving any midi data. Tracks need to be input monitor enabled before you will hear anything too.
There's a screenshot in the link in my last post that should help you with that.
PreAl wroteI've already been through this, follow this thread carefully beginning to end. A few screenshots may help you as well. Most setup areas are covered (maybe not in the right order). Thanks for that link! It's good to know it can be changed to work on one MIDI port using OMNI mode. I have the A-300PRO and have always used it with the default two port setup, one for the keyboard, and the second for control surface messages. I just got used to using it that way with Sonar and the ACT plugin, and never realized you could combine them. So using two ports in Studio One just seemed normal to me. This 'feature' probably catches a few folks by surprise! Now that I know about this, I looked again at the Roland manual section 'Specifying the current MIDI channel', under 'OMNI ON' explanation. I can see the brief mention about the current channel, and the KEYBOARD PORT. Never really payed attention to the meaning of that port thing in regards to OMNI. |
tomgastauer1 wroteI'm having trouble getting my Roland keyboard controller to work in Studio One.......... That won't work. That is the external MIDI interface connector on the side of the A-PRO. If you want to use the USB driver, the internal keyboard MIDI is fixed to Port 1. Select receive from 'A-PRO 1' in Studio One > Options > External Devices. |
JohnBW wroteThanks, I have, I apologize I didn't put that in my original post. I've used every combination of A-PRO 1 IN/OUT and MIDI IN/OUT that is available. Nothing worked.tomgastauer1 wroteI'm having trouble getting my Roland keyboard controller to work in Studio One.......... Sent from my SM-G930P using Tapatalk |
tomgastauer1 wroteJohnBW wroteThanks, I have, I apologize I didn't put that in my original post. I've used every combination of A-PRO 1 IN/OUT and MIDI IN/OUT that is available. Nothing worked.tomgastauer1 wroteI'm having trouble getting my Roland keyboard controller to work in Studio One.......... This is my basic setup for the A-PRO in Studio One, as far as simply playing the keys (so not including control surface setup). Just fyi: I named my MIDI port 1 'A-PRO 1 MIDI', but not to be confused with 'A-PRO MIDI IN' From chapter 5 in the Studio One user guide: Configuring an Instrument Track |
Users browsing this forum: AAV and 96 guests
