Link track selection?
Posted: Thu Mar 29, 2018 6:40 am
by pawelhebda
Could someone explain what it does? I can't figure out. What track does it linking?
Re: Link track selection?
Posted: Fri Mar 30, 2018 2:02 am
by pawelhebda
any one?
Posted: Fri Mar 30, 2018 8:21 am
by robertgray3
I had the same question as you when I was learning the MIDI Editor. Then I noticed this from the comment section on one of Quanta’s S1 tutorials on YouTube:
“This one had me intrigued. I spent a few minutes and found something. If you have the "Track List" open and you have two or more midi tracks going on, it does do something. With the Button on if you have the little white buttons for each track on it will just show the track selected midi notes of the track you select. If you have the button off and have several midi tracks with the white buttons on, it will highlight those midi notes of that track on top. Probably more useful if you have overlapping notes on different tracks. Also, depending on if the "pencil" button on the track list is on or off it allows you to see other tracks and only edit the one you want. You have to deselect the pencil track so you don't accidentally edit the wrong track. Cool little feature I didn't know was there.”
I don’t use the function much but maybe that helps?
Posted: Fri Mar 30, 2018 9:25 am
by phillipdixon
Thanks robert
I could'ent work that out
Cheers
Phill
Posted: Fri Mar 30, 2018 1:28 pm
by Jemusic
Nothing seems different to me with that button ON or OFF. Not sure what I should be seeing. This is on a Mac though. May be different on my Windows studio machine. Will check that.
Posted: Sat Mar 31, 2018 1:36 am
by pawelhebda
robertgray3 wroteI had the same question as you when I was learning the MIDI Editor. Then I noticed this from the comment section on one of Quanta’s S1 tutorials on YouTube:
Thank you - I don't know if this feature is usefull but good to know that is it for
Posted: Sat Feb 01, 2020 4:57 pm
by rogervincent
Hi All, I'm working in Studio One 4.6.0.55605 on Windows 10 and I don't see the 'Link Track Selection' button at all. Was it removed from the version I'm working in?
I've attached a word document with a screenshot of the music editor, clearly showing that the 'Link Track Selection' button is not present.
Can someone help me out?
Posted: Mon Feb 03, 2020 9:21 am
by robertgray3
From reading the description of it I think it's no longer toggle-able now. My guess is everyone left it at its default and they cleaned it up. Perhaps as part of the noble effort to make Multi-Track editing capabilities easier and more convenient (they're getting there!)
