Hi. I'm curious what S1 does when using your main interface and an ADAT connected one? For example, my Apollo has an RTL latency of about 3ms. When I use Pipeline, the ping lines up almost perfectly, I usually move it 1 or 2 samples. But I also use a Presonus DP88 as an ADAT extension, and when using for a pipeline hardware connection, I usually have to bump it up like 40 or 50 samples to line up.
So, if I'm using both on my 2 buss, I have 2 inserts both needing different latency times to complete the RTL. Does this create any weirdness or phasing issues? Does S1 just take the slower RTL's and then move shift the timing globally to accomodate for that? Hope my question is making sense. I'm not noticing any issues by using these 2 interfaces for Pipeline connects but it feels kinda weird. I'm considering picking up another apollo since I can daisy chain, and have only 1 RTL figure to deal with. Is this an issue I should be concerned with? Thanks in advance, Cheers |
Users browsing this forum: No registered users and 90 guests
