i have some sort of setting out of whack
when i engage an instrument to record the volume drops and i have to constantly adjust it can anyone help thanks guys all of my software is upto date and im using windows 10 asio |
Do you mean:
When I arm an instrument track for recording, the volume of it drops. Or, When I compare the playback of the instrument track to when I monitor to record on it, the volume changes. Please be more specific as the the nature of your issue. Thanks. |
jamesrutherford wrotewhen i engage an instrument to record the volume drops and i have to constantly adjust itWhen you have Dropout protection set to anything else but Minimum, try to set it back to Minimum. If that solves it, you probably have a plugin in the low latency monitoring path of the instrument, that is introducing a latency > 3 ms. The audio signal of Instruments with Low latency monitoring for instruments enabled, will bypass plugins introducing a latency > 3 ms when monitored. Instruments within a Low latency monitoring for instruments path, have a green instead of blue activate button and a Z on their channel(s). Inserts on the channels that are included in the low latency path also have a green activation button. Inserts that are (partially*) bypassed ( > 3ms) are lacking a clear visual indicator of their current state and are just blue. * When on a bus receiving low latency and non low latency paths. |
Users browsing this forum: steveevans1968 and 27 guests
