hi everyone, if one zooms out enough as to not see any markers is there a way to locate a marker without zooming back in?
in sonar there was a marker box in the transport that had a horizontal slider and a drop-down with all the markers which enabled one to click on the marker one wanted. does studio one have anything like that? thanks so much. jp
OS Name Microsoft Windows 10 Home
Version 10.0.14393 Build 14393 OS Manufacturer Microsoft Corporation System Manufacturer HP System Model HP ENVY m7 Notebook System Type x64-based PC Processor Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s) installed Physical Memory (RAM) 16.0 GB Total Physical Memory 15.9 GB Available Physical Memory 11.9 GB Total Virtual Memory 18.3 GB Available Virtual Memory 14.2 GB Page File Space 2.38 GB INTERFACE/ ROLAND QUAD-CAPTURE |
I am at work so not in front of S1 to tell the exact keys to use, but open the keyboard shortcuts to the transport section and they will be listed. I do know the keycommands are using the numberpad on the keyboard.
Hope that helps. |
Right click right on the timeline and the marker list pops up. You can select a specific marker right there and the cursor will immediately jump to it.
Shift + N (to the left) and Shift + B (to the right) will also allow you to jump markers.
Jemusic wroteRight click right on the timeline and the marker list pops up. You can select a specific marker right there and the cursor will immediately jump to it. Learn something new every day. Thanks for that. |
I'm away also, but maybe this will help. I'll use the keypad, and just remember that two higher is the number of keys to marker number.
So: 0 is always return to zero time (or first return to start of play, option depending, then to zero). 1 is the loop start 2 is the loop end 3 is then marker #1 4 is then marker #2 ........... etc. 9 is then marker #7
Lokeyfly wroteI'm away also, but maybe this will help. I'll use the keypad, and just remember that two higher is the number of keys to marker number. That's what I couldn't remember. Thanks. |
Lokeyfly wroteI'm away also, but maybe this will help. I'll use the keypad, and just remember that two higher is the number of keys to marker number. Nice, cuz I usually zoom in and zoom out too... maybe I can work smarter? So as the OP stated, you're zoomed in and don't want to zoom back out, so (as Jemusic says) you open the "Marker List". What I can't remember is if the actual Marker Names show or if they're only listed/shown as numbers? The manual states you can rename Markers and I also seem to remember that there were preset names to choose from when inserting a new marker? When I insert a new Marker, it shows as a number, then I rename it immediately. Hmm.
-S1 Pro 5.5.2. Win11 Pro 22H2. Behringer UMC404HD. Melodyne Studio 5.3.1.018. -MSI 12th Gen i7, 16GB, 1GB SSD x2, 7200rpm 2TB HD, NVIDIA RTX 3060. -EZD3 & EZD2. Helix Native, Scuffham S-Gear. iZotope Ozone 5. -Akai MPK249. 6 Guitars. Line 6 Helix LT, 2 POD's & an E-bow. -Adam Audio T8V's. Dual 28" ViewSonic Displays. Rode NT1. SM58. Original Faderport. -Just My Songs -My Previous Band: 2GUYZINABASEMENT |
If you rename a marker then when you look at the marker list (right click timeline) then the name also appears there. Alongside Marker 1- Name etc.
There are no preset options for markers. I think you maybe thinking of the arranger timeline which there are preset names for song sections but these are also easily renamed. The numeric pads are not much help when you have got 247 markers in one session which I had recently in a job. They are only good for 7 markers really in one session.
Jemusic wroteThere are no preset options for markers. I think you maybe thinking of the arranger timeline which there are preset names for song sections but these are also easily renamed. Yes, that's it... preset names for "song sections" not the Markers. Having the Marker names is needed - I have just 13 Markers in a song and I can't remember where each falls. I'm going to review this newly learned/remembered technique tonite!
Yeah, I don't use many markers, so they usually are the start of major parts like Chorus 1, 2, Verse 1, 2, 3, intro, End, or some basic location. I use Shift + L quite a lot, because I'm always defining some loop area, and will zoom the loop from end to end. There's also blocks with some DAW's, but that's never appealed to me.
2 years ago, I bought this Microsoft touch mouse. Nice item. You can whisk along the timeline with index finger going sideways along the top of the mouse. Then up down zooms in or out. You can also create macros so that once you click on an event, the timeline will go to it's start. It's largely a matter of creating workflows that work for you. Naming markers might have their place for some things, but its never been anything I felt I had to do. Mmv. If so, right click on the timeline for those places. I'm sure Jemusic had a lot of cue points for 247. But just shows you there's different needs for each of us.
i really don't like using that "thumbs up" thing, i think it's rude when people take the time to answer my questions.
so, thank you all, this was a lot of help. jp
scottyo7 wroteHaving the Marker names is needed - I have just 13 Markers in a song and I can't remember where each falls. I'm going to review this newly learned/remembered technique tonite! Not sure if this is what you mean but you can easily rename markers just like media clips, from the macro toolbar menu... Also, the Insert Maker action has a Name argument, if you want to make macros to insert already named markers. |
Lokeyfly wrote I'll use the keypad, and just remember that two higher is the number of keys to marker number.. ...... For the sake of our refugees, remember that all keyboard commands are editable. So if you're like me and you don't like the offset, just remap all of your numeric keypad numbers to markers. |
mikemanthei wroteLokeyfly wrote I'll use the keypad, and just remember that two higher is the number of keys to marker number.. ...... Absolutely. I just like 1 and 2 to be the loop start and end, so it was painless to deal with as is. But hey, have a blast modifying. I'm pretty sure this is a family of users from many walks. I make no distinction, and wouldn't bore, anyone with my previous DAW's used. Don't expect to hear theirs either. But case in point for "peeps", who just don't know that the keys are editable. Point taken.
Sorry for any bad spelling. My spellchecker is getting Picaso creative again.
my spelling is on a 3rd-grade level as well.
Lawrence wrotescottyo7 wroteHaving the Marker names is needed - I have just 13 Markers in a song and I can't remember where each falls. I'm going to review this newly learned/remembered technique tonite! i haven't progressed to the macros level yet. thanks you for your answer.
Users browsing this forum: No registered users and 71 guests
