Studio One song hangs on save "Packaging: editor.xml"
Posted: Tue Jan 16, 2018 6:17 pm
by robbryant1
I have one song in S1 that is hanging when saving, other songs save as normal.
The dialog box will show "Packaging: editor.xml" and hang for about 1 minute. Sometimes it is a different xml file.
Any ideas about what might be causing this? It isn't an unusually complex song.
Obviously it is quite disruptive, especially if autosave is on, as S1 won't respond to any inputs until after that save process has completed.
Re: Studio One song hangs on save "Packaging: editor.xml"
Posted: Tue Jan 16, 2018 8:37 pm
by matthewgorman
What version are you using?
Posted: Wed Jan 17, 2018 3:31 am
by robbryant1
Hi Matt, thanks for getting back. I'm on the current version 3.5.4, I'll update my profile to show my setup.
Posted: Wed Jan 17, 2018 4:38 am
by Morticia
Try saving a copy of the song to a different location - 'Save to new folder' option
It could be a disk I/O bottleneck of some kind or possibly a faulty disk sector.
Are you saving to a fixed disk or a removable one ?
Posted: Wed Jan 17, 2018 6:00 am
by robbryant1
Thanks @Morticia I tried your suggestion and while it didn't work, it left me sitting in front of a copy of the song so I experimented with the copy, and figured it out.
I deleted all the tracks I added yesterday, and it saved normally. So I restored them, and through a process of elimination worked out it was a few tracks that originated in Reaktor Blocks. It was a drum beat where I had split the instruments and soloed them on the instrument track, then copied that audio to a new track, and repeated that process. I'd then created loops, edited them in Melodyne, and bounced them.
Somewhere in that process there is something that ties up the processor when writing the xml files.
I did a mixdown / load to track for each of the tracks and copied the effects over, then deleted the original tracks (which had drag and dropped clips from the Reaktor instrument track) and it saves normally now.
Posted: Wed Jan 17, 2018 7:22 am
by Morticia
Glad you got it sorted out
I would suggest that it would be excessive disk writes that are causing the CPU to wait, rather than the CPU maxing out though.
If you get the issue again, launch Task Manager while it is happening (if you are able), go to the Performance tab and see whether the bottleneck is CPU, disk or memory.
Edit: Just a thought -
if when the save was happening, S1 was trying to read the Reaktor Blocks loops from the same disk device whilst also trying to write to the same disk device (in order to write out the data) , then you would have a classic case of disk I/O contention.
It is good practice to have loops, samples, patches etc. on a separate physical disk to your Songs / Projects for that very reason.
Posted: Fri Mar 06, 2020 12:22 pm
by erikvannieuwburg1
I've got the exact same problem. It's all related to a single track. And specifically to the MIDI events, so agnostic of the instruments.
But! I figured it out! The midi events had Layers packed underneath the tracks. As soon as I removed all the layers and simply used a normal events, all CPU issues were gone and it saved my project in a jiffy.
Posted: Wed Nov 04, 2020 3:00 pm
by saulchacksfield
erikvannieuwburg1 - you just saved me. Thaaaanks.
Posted: Tue Jan 18, 2022 8:10 pm
by joelaviles
I had the same problem, and all I did was save everything that I was working on and restarted the computer! No more problems! Yay!!šš»š¶š¤
Posted: Sat Jan 14, 2023 11:06 am
by bunkeraudio
Iām having the same issue with the sessions Iām using Vocalign on even if I bounce the tracks that are aligned. Havenāt found a solution yet..
Posted: Mon Feb 06, 2023 11:35 pm
by adamwatson
Iām having the same issue as bunker audio. Iām having saving issues because of VocAlign. I keep on seeing a pop pop up that says packaging, aramode.dat. And it always takes forever to save. Help.
Posted: Sat Feb 25, 2023 12:37 pm
by jonahkoslen
Same problem here.
Last Wednesday my current song began acting up.
I was working on a song from the day before and when it went to auto save, it froze with the beachball spinning.
It stalled, stuck at āPackaging: Pan L_R(3).envelopexā.
The song won't "save" or "save as" without hanging there.
Iāve tried saving to a different directory and hard drive, still the same thing.
I tried opening an earlier version and tried saving it to another drive, but that failed as well with the same message.
Any insight is greatly appreciated.
Mac, Ventura, Studio One Pro 6.02
Posted: Fri Mar 24, 2023 10:55 am
by guntherpott1
Same issue here. Started with the current song/ project a few days ago and still happens after updating to S1 6.1 from 6.0
Mine got stuck mostly on āxxxxxx.vstpresetā, only a few times it froze on something else. When it did the last āletās freeze that sucker at .vstpresetā, I did the next S1 re-start with VST 2.4 disabled (even though I do not actively use any VST 2 in my projects, only VST 3 or AU. Strangely enough, that worked, so then I went into the advanced section of the preferences in Studio One and disabled VST 2.4 support. I donāt understand the connection there, but so far, things are working normally.
MacBook Pro M1, MacOS 12, everything completely up to date.
Posted: Fri Mar 24, 2023 11:39 am
by guntherpott1
Well, just froze up againā¦.so that wasnāt the solution.
Posted: Sat Mar 25, 2023 10:46 am
by guntherpott1
OK, digging a bit further, I noticed that the Song folder I was working in was absolutely bloated with just under 50GB (!) of data and way (too) many .song files. After I did some serious house cleaning inside that folder, the issue with the freeze was gone. So far so good.
Posted: Sat May 13, 2023 6:13 pm
by ronnymosuse
Solution for the packaging save problemā¦
https://youtu.be/vaqNs_9S30g
Posted: Mon Oct 02, 2023 4:58 pm
by musicpresonus
Thank you!!! Took care of my problem!!!!
