klypeman wroteI added this to the pathlist and it works now finally. Add that path in studio one vst Worked for me too thanks for that. |
PreAl wroteNow the easy way. That's exactly the right way to do it. Worked for me like a charm too. I have many, many Waves plugins and on times when I get a new one, this sometimes happens. I just do the above steps and voila. Fixed. Doesn't take long at all.
johnbaybutt wroteklypeman wroteI added this to the pathlist and it works now finally. This is NOT the good way to do it. You may get plugins that show up that you do not own.
The waves plugins are kind of odd. Try adding the location;
"C:\Program Files (x86)\Waves\Plug-Ins V9" Or the relative folder ( V10 ). It seems like pointing to the root of the waves folder does not always allow the plugins to be scanned, once I pointed to the actual folder then the plugins appeared. Good Luck! I know this drove me crazy for a while, hope it helps. |
netman8762 wroteThe waves plugins are kind of odd. Try adding the location; Please read the comment just before you posted, then check out my comment above which was quoted in the comment just above that.
Hey! Sorry to bump an old thread, but I've found myself with the same problem: I've changed my computer and I've been moving all of my plugins, and I've got 5 or 6 Waves ones that I can't seem to get to appear in Studio One 5.
As other people have also noted, when I run the DAW, the plugin scanner shows that it recognizes plugins such as "WaveShell1-VST3 11.0_x64", but no Waves plugin appears in the effects list inside any project. I've tried every possible solution from this thread (and others), with no success. I've put new directory paths, as some recommended, but then some Waves plugins I don't have appeared (without GUI, they were all black). I moved my licenses to my cloud and then reinstalled them in my computer, but it made no difference. This is a bit annoying, since I'm in the middle of a couple of projects and just when new jobs start to come, problems start to appear. Any help would be greatly appreciated, thanks! |
PreAl wrote Have you run and updated waves central? You must follow this exact procedure above.
PreAl wrotePreAl wrote Hi! Yes, I did that too. I installed Waves Central in the new computer just yesterday, so I supposed in would be up to date, but I checked anyway just to be sure and it is. I tried the procedure you metioned and nothing. Anyways, I don't have anything else to try, so I might as well try this again just in case. Let's see if second time is the charm... |
polprats wroteNope, tried it for a second time and nothing... Use the Plugin Manager in Studio One. Open it up and hit the Rescan Plug-ins button at the bottom (I think that’s what it’s called). This will typically re-scan the Waves shell, notice any changes, and they will be there after rebooting. I had to do this every time I purchased a Waves plugin. |
One other piece of advice. Use the Plugin Manager or the wrench icon in the Effects Browser to make sure they aren’t just hidden. There are some situations where Studio One will accidentally hide plug-ins in the browser, usually involving a crash or an update.
allrics wroteIn the search bar can't you just type in Waves and see where they put your plugins? And then use that in PreSonus VST page. Pretty sure they tried that multiple times- that’s basically the same piece of advice that’s been given a dozen times in this thread. I think the issue here is that when the Shell changes due to an update or a new license you usually have to explicitly tell Studio One to re-scan the Shell. Hence my recommendation to try the Plug-in Manager’s rescan command. |
Resurrecting an old thread again... anyone found any alternatives to all the suggestions here (which I've tried!)?
On Mac, Big Sur. Just did some updating of some Waves plugins and Studio One etc and back to the familiar old cycle of tearing my hair out to try to get SO5 to 'find' all my Waves plugins. Its randomly recognising a handful, including Studiorack. Within Studiorack I am able to load all of my Waves plugins. This makes me think it is a) not a licensing issue and b) not a Waves installation issue, but definitely something to do with Studio One itself and the way it scans. I have clicked every possible 'reset blacklist' button, 'rescan plugins', 'reset plugin settings' blah blah. Tried a fresh installation of SO5 (even tried SO4 for a laugh ). Tried all the steps mentioned here. I have 2 machines that I use (thankfully I haven't updated my main one yet!) and I can see that everything is in exactly the same location on both in terms of plugins, Waveshells and paths within SO5. The only difference is on my main machine I haven't updated a couple of my plugins and its still working perfectly. Anyone found a magical solution? Thanks |
gavinmathers wroteI have clicked every possible 'reset blacklist' button, 'rescan plugins', 'reset plugin settings' blah blah. Tried a fresh installation of SO5 (even tried SO4 for a laugh ). Tried all the steps mentioned here. See my post above, you tried that with no shortcuts, 7 steps? You are on the latest studio one?
Over the years Waves' continued usage of the Shell wrapper things have cause me no end of problems in several different DAWs. Even now I sometimes get a random error when S1 starts up that says some plugins will not be available until I restart the program. I've kinda given up on them.
Do a support ticket with them, they helped me out. I let them change some settings and it was up and running again.
I've never upgraded waves plugins, just kept buying them so I have different versions but they all work. Just noticed tax day sale today, everything $30.
PreAl wrotegavinmathers wroteI have clicked every possible 'reset blacklist' button, 'rescan plugins', 'reset plugin settings' blah blah. Tried a fresh installation of SO5 (even tried SO4 for a laugh ). Tried all the steps mentioned here. Yeah I've tried, thanks. Will have to speak to Waves! |
https://www.waves.com/support/tech-spec ... quirements
**You need High Sierra to run version 12 of WAVES. Operating System 10.13.6, 10.14.6, 10.15.7, 11.2.1 (Intel only) **What you need to do is install the version 11. Thats what I do here. Also, version 12 REQUIRES you to have a Metal compatible video card in your Mac ***The WAVESHELL is just a container that points to the actual plugin location. When the WAVESHELL works it then scans the VST plugins folder. Also, WAVES uses VST3 so in StudioOne you need to go to the : Preferences/Advanced/Services and make sure VST3 is enabled. Waves can use AU as well but I always disable AU since I had issues before with Waves AU inside of S1 |
