I recently bought two Waves plugins -- Abbey Road Plates and TMG 12345 -- and they are not appearing in the lost of effects.
I have closed and re-opened Studio One (running 3.5.4, on OSX Sierra, btw) When I look in the library locations for VST plugins, all I see is "WaveShell-VST 9.91.vst", and that does not show up in the S1 effects list either. I have successfully used Waves Central to "Install and Activate". Any ideas? |
When you first load S1, the scrolling messages as things load, do you see a line saying its loading Waves Shell 9 VST or something similar? I see this every time I load S1. Waves shell is not a normal VST, it is some wrapper for their stuff I believe.
I should know this since I have done it so many times, is there not another step after activation to place it on your computer?. Maybe I am getting my ILOK and Waves license process mixed up. You could download the demo of Reaper and check if it sees them.
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR, Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC. |
I don't normally have the scan box checked. So when I buy something I go in and check it then click apply and it finds the plugs then uncheck it. Guess should save some time on every startup.
I have had this issue a couple of times. It has happened when I have purchased a new Waves plugin and have needed to reinstall Waves Central. I don't believe is a Studio One issue. I am sorry that I cannot give you a definitive solution but I can offer two suggestions that have worked for me in the past. These solutions assume you have already set and checked the file location settings in Studio One. 1/ Start Again Is this the first time you have installed Waves in the PC?? ... or is it a reinstall with the new plugins? My experience has been that Waves seems to do wonky things when I do an upgrade or reinstall. I have found that to overcome this I need to remove every last scrap of Waves from the PC, Then do a full reinstall of Waves Central. 2/ Waves Licences The last time I had this issue I resolved it by moving all my Waves licences back up to their cloud. Rebooting the PC and then moving the licences back down to the PC. The plugins then appeared in Studio One as they should. (Might have to do a re-scan) I think suggestion number 2 could be worth a try. Let em know how you go. John B
Win 7 64-bit, 4 Core i7: 16Gb DDR3 ram, Dual 20" LCD monitors
Audiobox 1818VSL, DigiMax D8, Central Station Plus, Faderport, Sceptre S8, Avantone Pro Mixcubes, Eureka Preamp (5 of), Studio One Pro 3.5.4, Notion 6, PreSonus Symphonic Orchestra, Superior Drummer 2, CTC-1, Channel Strip Collection, Melodyne Studio 4.1, Waves Plugins |
This just don't work as I for the first time in 2 years got through the online install today !!! Then happily read all that's on this site to know how to not screw up and still no go..... I think I just Wave goodbye to Waves.....
I have this same problem, my waves does not work in studio one, I am frustrated with trying to fix this, it works perfect in Logic Pro, also my UAD plugins work in both Logic Pro and Studio One.
Anyone has a Fix for This ? [email protected] klypeman wrote:( This just don't work as I for the first time in 2 years got through the online install today !!! Then happily read all that's on this site to know how to not screw up and still no go..... I think I just Wave goodbye to Waves..... |
I tried again I'm only getting WAVES STUDIO RACK showing up. however I'm getting access to more waves plugins if I put the studio rack plugin on a channel. weird. but maybe that can help until there is a real fix.
[email protected] wroteI have this same problem, my waves does not work in studio one, I am frustrated with trying to fix this, it works perfect in Logic Pro, also my UAD plugins work in both Logic Pro and Studio One. |
Have you tried contacting Waves customer support? They have always been quick to reply and very helpful when I did. I would give that a try before throwing in the towel! Best of luck, I hope you get this fixed!
Peace!
Dan PreSonus Studio One Professional 6.0.1 Windows 11 Home Edition 64 bit Rocket Lake Z590 Desktop PC with Intel i5-11600K processor @ 4.60 GHz / 32G RAM Intel UHD Graphics 750 LG Full HD Monitor 1920 x 1080 at 60Hz 16:9 Aspect Ratio Toshiba HDWD110 1TB System Drive and HDWD110 1TB Audio File Drive, Samsung SSD 850 EVO 500GB and Samsung SSD 970 EVO Plus 1TB Samples Drives, Seagate BUP Slim BK 2TB USB Backup Drive PreSonus 1824C Audio Interface PreSonus Faderport 2018 PreSonus Studio Channel, Klark Teknik EQP-KT, KT-2A and 76-KT Check out my website http://www.dlsmusic.net |
I have a few Waves licences. All are working fine here.
Jonny Lipsham - Studio One & Notion Specialist
Scan 3XS Audio PC (Octa-core Intel 9th Gen i7 4.5GHz 16GB RAM) Windows 10 Home Advanced | 21.5-inch iMac 2.3GHz dual-core 7th gen Intel Core i5 processor, (Turbo 3.6GHz) 8GB 2133MHz DDR4 | Studio One Professional | Notion 6 | Notion Mobile | Audiobox 96 USB | Studio 1824c | StudioLive 32SC mixer | FaderPort (2018) | Monitor Station v2 | Eris E5 & Eris 6 Pro monitors | HD7 & HD9 cans |
I just purchased several new Waves Plugins and am having the same issue. All of my prior Waves Plugins show up but not the new ones. I researched the hell out of this and did everything that comes up by Waves and by Presonus. (noted links here) They did not work. Then I decided to add this new VST Plugin path to Studio One 4 and the missing "NEW" plugins show up.
C:\Program Files (x86)\Waves I do not see this noted in any documentation and may be I missed it but this worked for me. Good Luck. John
Music is moral law. It gives soul to the universe, wings to the mind, flight to imagination, a charm to sadness, and life to everything...Plato
https://soundcloud.com/jagrandesr https://astrat.wixsite.com/meadow-ridge-sound AMD Ryzen 7 1700 3.0GHz, 32GB RAM, 7TB Gea rDrives, 2x 256GB SSD, GTX-1070, Windows 10 64bit, Sonar Platinum 64bit, Studio One 3/4, RME-BabyFace, Triple 27in ASUS Monitors |
I added this to the pathlist and it works now finally.
C:\Program Files(x86)\Waves\Plug-Ins\V10
I had this problem with my last purchase “Plate Reverb”. I just purchased C6 and had the same problem.
The support representative did some troubleshooting and eventually created this path: /Library/Audio/Plug-ins/VST3 I don’t understand exactly what was different because I’ve had no problems accessing VST3 plugins before. But it worked. He also suggested that I share this information with the forum. VST3 is the format they’ve officially qualified to use on Studio One.
Mac Mini (Late 2014)
Astrat wroteI just purchased several new Waves Plugins and am having the same issue. All of my prior Waves Plugins show up but not the new ones. I researched the hell out of this and did everything that comes up by Waves and by Presonus. (noted links here) They did not work. Then I decided to add this new VST Plugin path to Studio One 4 and the missing "NEW" plugins show up. OK so after being able to access my new waves plugins using the method above I found that using this path also loaded plugins I did not purchase. When you try to load one it comes up blank. So I deleted the path noted in my original post above and restarted Studio One. The new plugins were still there. What the FACK! This is not acceptable from Waves...seems to always be something when I purchase from them.
Hi All, I also got Abbey Road and JJP Strings/Keys as a Christmas gift and was having the same problem. All the older ones worked, but these last 2 refused to show up in Studio One plugin scanner.
Here's how I got the new ones from Waves to show up in Studio One: 1. At the home/start screen in Studio One, select the Locations tab and the VST tab up top. 2. I added a new file location for EACH of the plugins that were missing by including the "Contents" folder in the path: [Abbey Road] C:\Program Files (x86)\Steinberg\VstPlugins\Waves\Abbey Road TG Mastering Chain.bundle\Contents\Win32 [JJP Strings/Keys] C:\Program Files (x86)\Steinberg\VstPlugins\Waves\JJP-Strings-Keys.bundle\Contents\Win32 3. Apply/Save the settings and rescan in Studio One. **P.S. Before the Studio One fix, I did request to reset my licenses in the Waves Installer/Manager by sending ALL licenses to the Cloud and then reinstalling back to my computer. So if you can't get the plugins to work in Studio One after the above instructions, try reinstalling your Waves Licenses through the Installer/Manager. Best of Luck!! Nene |
Now the easy way.
1) Start studio one. 2) Go to locations->VST Plugins 3) Take note of the locations in case you need them for future reference. 4) Delete ALL your locations. Yes ALL of your locations. 5) Reset black list. 6) Restart Studio One twice. Yes twice. 7) New project. Test your plugins For me that was enough to get it to work, I didn't need to enter manually any plugin paths back, but if you really need to, do that.
Users browsing this forum: No registered users and 77 guests
