My Session Horns Pro samples get all mangled up after about fifteen minutes when using it in Studio One. I'm a Sonar refugee and I never had this problem before. I tried purging the sample pool, reloading all samples and nothing works. The only way to fix it is to close the song and reload it.
Anyone else have this problem and if so, is there a fix?
Peace!
Dan PreSonus Studio One Professional 6.0.1 Windows 11 Home Edition 64 bit Rocket Lake Z590 Desktop PC with Intel i5-11600K processor @ 4.60 GHz / 32G RAM Intel UHD Graphics 750 LG Full HD Monitor 1920 x 1080 at 60Hz 16:9 Aspect Ratio Toshiba HDWD110 1TB System Drive and HDWD110 1TB Audio File Drive, Samsung SSD 850 EVO 500GB and Samsung SSD 970 EVO Plus 1TB Samples Drives, Seagate BUP Slim BK 2TB USB Backup Drive PreSonus 1824C Audio Interface PreSonus Faderport 2018 PreSonus Studio Channel, Klark Teknik EQP-KT, KT-2A and 76-KT Check out my website http://www.dlsmusic.net |
No issues here using it on my PC, Win10 w/16 GB RAM. Haven't noticed any kind of wonky behavior with this. But everything NI is up to date here, as well. Maybe check that you are, too.
Also, my dropout protection is minimum. Buffer is at 64 or 128.
Thanks for your kind reply! My buffer is at 512. How would buffer size affect Konakt performance?
Peace!
Have you run Native Access for updates?
PreAl wroteHave you run Native Access for updates? Yes, I'm at the latest version. It's driving me nutty! I also put in a help ticket with Native Instruments but the fact that it's working in Sonar and not Studio One is odd. Any other suggestions would be much appreciated!
Peace!
Unfortunately something working on X isn't going to help you when trying to get something working on Y. 90% it points to an underlying problem that hasn't been picked up by the other software (because it works a different way).
I can give you general performance tips. 1) If you have turbo features on your motherboard BIOS turn it off.. 2) In Windows power saving advanced you will see CPU min/max. Make sure these are on 100% 3) Update your display and audio drivers. 4) Consider updating motherboard BIOS 5) Make sure your antivirus excludes DAW processes and files (do not disable). 6) Run windows update. 7) Goto Intel driver update website (or AMD equivalent). 8) Update Studio ONE. Once you've done all this download a copy of process explorer and latency monitor and get troubleshooting. Kontakt often throws in convolution reverbs into their presets .. removing them often saves on CPU. Cheers. Edit Probably won't help your samples getting mangled up though... And I'm not sure what it means. So I also suggest uninstall and reinstall.
I think you work with orchestral sound?
Just an extra tip: Wait for the full load kontakt(s), before playing or editing your song |
PreAl wrote Are you suggesting I uninstall and reinstall Session Horns Pro or Kontakt?
Peace!
Either or both. I've just given you a number of suggestions for you to pick and choose upon. I can't supply a definite answer.
If you are removing and reinstalling via Native Access it's not a hard one to try. You could also contact NI support. Again not really sure what "mangled up" means.
PreAl wroteAgain not really sure what "mangled up" means. Sorry PreAI for using the word "mangled" . By that it means that all of a sudden the sustained parts of the notes no longer play, I just hear that attacks. And eventually, I hear nothing.
Peace!
Cool, well above are only suggestions. It's a worthwhile exercise trying all of them anyway, you are likely to walk away with a better sysmte imho. Then I guess you go for NI support.
Cheers.
daniellesaux wroteMy Session Horns Pro samples get all mangled up after about fifteen minutes when using it in Studio One. I'm a Sonar refugee and I never had this problem before. I tried purging the sample pool, reloading all samples and nothing works. The only way to fix it is to close the song and reload it. Yes I have the same problem but on Sonar Platinum. (Win 7, i7, 16gig). "Mangled" describes the symptoms very well. Have you solved the problem yet? You're right. It drives me crazy. |
Do you have the Komplete Kontrol keyboard as well?
I'm not sure if it was the latest version of Komplete Kontrol or the latest update to S1 (as I got both at the same time), I now have to specifically select the model of my keyboard on each track's Instrument. I used to be able to just leave this to "All". If I leave it set to all, I get all kinds of wonky behavior. Selecting the exact model of keyboard fixes it. (You have to have your keyboard defined, of course, in the MIDI settings of Studio 1).
Session Horns Pro is the biggest CPU Hog that NI produce. Do you have other instrument tracks on the go while this is happening, lastly what reading are you getting off your performance meter? I ask the question because I use it and only have 4 GB of RAM but I have to have all other tracks rendered (Frozen) before doing so.
https://soundcloud.com/gerry-cooper-855281238 Windows 11 64 Bit, Installed Ram 16 GB, DDR4 3600 MHz, 11th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz |
Check the Kontakt effects for convolution reverbs and delete them.
I'm having the same problem, I think. At random times Session Horns seems to develop a mind of it's own, skipping a lot of notes and hanging on others. Eventually one of the loaded horns will just sustain indefinitely until I close the song.
I'm going to try looking for the reverb IRs and see if I can work something out.
RS Cain plays Bitwood Guitars exclusively.
AMD FX9350 @4 gHz, 16 gb ram, 1 Tb SSD, 2 1Tb SS/Hybrid HDs, 1 Tb Fantom External HD, Windows 10 64 bit, Presonus Studio One 4 Pro, Pro Tools 2019.6, Izotope Neutron 3 Advanced and Ozone 9 Advanced, ARC 2, NI Komplete 11 Ultimate, TC-Helicon VoiceLive 3, Focusrite Saffire Pro 24 DSP, Focusrite Octopre MkII, KRK Rokit 8 monitors, Sennheiser HD 280 pro headphones, MidiMan Oxygen 8, Behringer X-Touch and Extender, Bitwood Guitars, and stuff. "TURN IT UP!" |
I'm having the exact same problem. Running S1 version Pro v. 4.6.2.58729. Windows 8.1. i have Session Horns Pro running in their Kontact 5 player. Seems random. If I play through the part for 10-15 minutes, notes stop playing, or one or two stay 'stuck' and keep playing. Saving, closing and reopening the song fixes the problem. Feels like some kind of a memory issue but I have a lot or RAM and don't have any issues running other plugins.
This is an old thread, but my first suggestion is, Kontakt 5 is no longer supported by Native Instruments. It's old. Yes, I know you are also on an old OS. However, I would suggest downloading at least Kontakt 6 player and seeing if that resolves the issue.
Users browsing this forum: BobF, DavidMaurand, Tacman7 and 82 guests
