This says solved but i thought I'd throw my 2 cents in. I forgot that once you solve a problem on presonus on A song, it doesn't solve the problem on THAT song. I got my Roland working on a new song and went back and it didn't work on what i was working on. I remembered that it'll work going forward but I just have to deal with what I already started. Its not a problem, its a feature
If you have an issue I suggest your start a new thread, you'll need to supply a lot more info (no idea what you are trying to get across).
This is my thread, I am the OP. I've renamed the topic to something more useful as there are a load of tips here for A300 (etc) users
Just adding this for reference (might help others).
Add new keyboard Manufacturer = Roland Device name = A300 PRO Receive From = A-PRO 1 Send To = A-PRO Tick Enable MP3 Then go to the Mixer, click "External" tab, select A300 Pro and "EDIT" - then MIDI learn the surface knobs. They should work, if not you need separate controller and keyboard setup (see beginning of thread). For some reason this would not work before.
jpettit wroteI suggest you start over. The first video is how I learned to set up my A 800 Pro. To date it is the only method I’ve found that worked for me and I’ve used it for years. I was super frustrated and I searched and searched unsuccessfully until I stumbled on that one and I’ve guarded that method in a special folder on my desktop and on a separate drive just in case my system crashes.
Mac Mini (Late 2014)
PreAl wroteJust adding this for reference (might help others). My method is slightly different: 1st Device: Manufacturer = Roland Device name = A 800 PRO Receive From = A-PRO 1 Send To = A-PRO (Make default) 2nd Device: Manufacturer = Roland Device name = A 800 PRO Receive From = A-PRO 2 Send To = A-PRO
frank.crow wroteMy method is slightly different: If you read the thread from the beginning you will notice that is what I used to do (first post, second screenshot). Not any more.
PreAl wrotefrank.crow wroteMy method is slightly different: Not really necessary to get offended my intention was just to be helpful.
frank.crow wrote Nowhere here does it say I'm offended. If you follow the full thread, and bother to read the opening post, it will give you full instructions on how to move from a two device setup to one device and retain exactly the same functionality with keyboard and controller. That was the original purpose of the entire thread. It's a much neater and more optimal solution than the default setup, which is what you are running now, and what I had it set up previously. It took a lot of head scratching to achieve it but I got there in the end.
PreAl wrotejpettit wrotehttps://forums.presonus.com/viewtopic.php?p=156319#p156319 Thanks so much This fix worked for me.
Hi there,
I'm new to S1 coming from Sonar and owning an A800Pro. I was looking for some information on how to use my A800Pro with S1 and ended up on this thread. I very much appreciate the information provided, I have tested both methods (1 and 2 controllers) and both work perfectly. I was just thinking that it could be interesting to put more 'theory' on why it does work with one single device by activating the Omni = On @PreAl: all credits to you for sure but you mentioned it worked like this without a real explanation behind. Well the answer is very simple: The A800 has got 2 separate outputs as you've already noticed. The trick now is that if it does only work for you by defining 2 devices in S1 this is because the control map you are using is affecting part of the midi messages to one output and the others messages to the second output. Typically the keyboard keys would be sent through one output and the controls to the other output. You can leave it like this, this is not a problem but IMO this is better having only one single device to manage in S1. How to do it? basically you have 2 options: Option 1: if you edit your control map with the A800Pro editor you can specify, for each controller, which output will be used to send the midi message to S1. Here you can define only one output OR both outputs. Of course if you want to define only one device in S1 you need to do it for ALL A800Pro controllers (buttons, faders, switches etc...) Option 2: Set Omni = On. Why does it work also this way? Simple: because setting Omni = On does change/overwrite the transmit midi channel BUT it does also overwrite the midi output to which the controllers are sending. Say that your controllers by default are sending to A800 Out 2. If you set Omni = On all your controllers will send to both A800 Out 1 AND A800 Out 2 Again I certainly don't want to get any credit on the solution as it was not brought by me but as I like to fully understand why things work, I thought it would be interesting to explain it in more details. Cheers Eric |
Can any of you A300 Pro owners comment on whether it supports soft takeover of plugin parameters in Studio One? By this I mean, when you grab a knob or fader on the A300 that has been mapped to software knob/fader in one of your plugins, or in the studio one mixer window, does the software knob "jump" immediately to whatever value the physical knob is set to on the A300? Or, does the software wait to respond until your physical knob crosses the value already established on the software knob? This is a very important feature for my workflow.
Also, how many banks of knobs/faders does the A300 have? Are you limited to 9 knobs and 9 faders, or are the multiple banks supporting 18/27/etc. of each? This controller looks great - from a physical standpoint it's exactly what I'm looking for. If anyone can weigh in on the above questions I'd appreciate it. Thanks. |
AngusY wroteCan any of you A300 Pro owners comment on whether it supports soft takeover of plugin parameters in Studio One? By this I mean, when you grab a knob or fader on the A300 that has been mapped to software knob/fader in one of your plugins, or in the studio one mixer window, does the software knob "jump" immediately to whatever value the physical knob is set to on the A300? Or, does the software wait to respond until your physical knob crosses the value already established on the software knob? This is a very important feature for my workflow. Sorry for late response. The buttons appear to immediately jump, maybe there is another mode, don't know. I haven't figured out if there are multiple banks yet, if they exist at all, so I'll just point to the manual: https://www.roland.com/uk/support/by_pr ... s_manuals/
WORKAROUND - Getting A300 Pro to work with Analog Lab V without interfering with Studio One device mappings (sadly Studio One mappings cannot be bypassed).
*You will lose your existing A300 Studio One CC mappings* The trick here is to just make sure your Studio One map does not conflict with the Arturia map. Instructions Download and execute A-PRO Editor. Select a control map on your A-300 keyboard (say 1). File->Open->"StudioOne.mid" Hit Transmit and then Continue. Select a control map on your A-300 keyboard (say 2). File->Open->"Arturia.mid" Hit Transmit and then Continue. Select Studio One Map on A300 (did you use 1?) Edit device, delete all your control assignments, and new ones via MIDI learn. You could also try the XML file I've provided. Open Analog Lab plugin, hit cog icon, goto MIDI. Select Keylab MKII/Scale. You are done. Just select the Artura control map if you need Analog map to work, otherwise StudioOne map for the rest of your plugins. See attached ZIP file. If anybody has a better way (banks?) let me know. This is just one approach. Ultimately the real solution is to get this plugin to work properly with Studio One, not sure if it's the plugin itself at fault (likely) or studio one. Discussion about that is here: viewtopic.php?f=151&t=49471 UPDATE - Updated attachment on this post, the Arturia map had L1-L8 buttons that had same values as the Studio One map, now they are different (I haven't given them any values that are significant to the Arturia map (CC30-38), if anybody knows any good assignment buttons for Keylab MKII please let me know what the CC's are and we could use them)
Thank you. I have been trying to do this for ages and had no idea where to start. It’s starting to make sense now. I had previously set presonus audio interface up with Roland a600 which enabled me to use the keyboard but was unable to figure out what all the knobs etc did. I’m to have a try now to see if I can get it working properly to its full potential.
Users browsing this forum: No registered users and 73 guests
