Hello
Before I ask the question please be familiar with my setup, I have a single A300 keyboard that has controller with it like this. Please note how it's been set up: a) This shows how I've set up my Roland A300 Pro keyboard/controller (Please ignore the Faderport): b) I've set up a device here for it. The keyboard, the notes and pitch bend will play here but MIDI learn will not work so can't use controller features here, I can only play the notes on the keyboard! (plus pitch bend etc). c) So I've set up another device here for the same keyboard. With this I can set up the controller features and MIDI LEARN will work without an issue, but the keyboard notes and pitch bend will not play! So.. It works fine if I use both (b) + (c), What I want to do? Please observe (a) (b) (c) ! Combine working features of (b) + (c) into a single device rather than split it over two. Thanks.
Why?
jpettit wroteWhy? I don't know why I can't do this. I should be able to have just one running device for this not two. If you don't have a solution for this or thoughts on how I can get this resolved that is fine. For me I've spent absolutely ages on this and it's really bugging me. Many thanks.
Why do you want to combine the same keyboard under two device names?
Is the something that is not working for you?
jpettit wroteWhy do you want to combine the sane keyboard under two device names? The only way I can get it to work is to create two devices as I've explained. Creating just ONE device does not work, as stated I just want it to be ONE device. Please refer to OP for further detail. PreAl wroteIt works fine if I use both (b) + (c), If you look at what I wrote next to (b) and (c) you will observe the difficulties.
I suggest you start over.
1) delete you two devices 2) add just one Keyboard controller 3) Make sure it inputs MIDI notes and can MDI learn. If it doesn't STOP and report what it is doing along with pictures of the device window and how you set it up. . This was just brought to my attention https://www.youtube.com/watch?v=ZFnX27Yqn84 and http://forum.cakewalk.com/tm.aspx?m=2819727 Did you already reference this? I suggest you create a support ticket and you can hope that another A300 user sees this. IT very strange that a major brand an common keyboard would not work as both the keyboard and MDI learn the controls.
jpettit wroteI suggest you start over. I've already done that. I've set up a single device like (b) and that didn't work for the reasons I've explained next to (b). I also set up a single device like (c) above. The same issues occur as explained on (c) above. So the only way I could get it fully working was to set both up. Observe (a) on how I set up (b) and/or (c). Thanks.
We posted at the same time.
See my update.
jpettit wroteThis was just brought to my attention https://www.youtube.com/watch?v=ZFnX27Yqn84 Thanks Yes I've already seen the video but not the Cakewalk forums link, will check. And yes was hoping an A300 or user with similar keyboard may turn up (FYI using latest drivers and firmware in case anybody asks). Thx for your help.
I am guessing that keyboard sends MIDI data out one port and Controller data out another port?
Don't know no never seen it six years here. Please look at you PM as I ask you permission to clean up the other thread.
viewtopic.php?p=156319#p156319
Also look at Jeff's question here. You can see MIDI data coming into S12 via the monitor. THere may be a configuration you have to do in A 300 to align the controller data and MIDI data on the same port.
Have you had this for a while? Have you seen it work with another DAW? I had a quick look at the manual and it may look like you have to set up every control to send out. Have you done that. (I could be wrong on that)
Are you using USB or midi? Have you tried it over Midi? I have never been a fan of the USB connection for things like this.
Jemusic wroteHave you had this for a while? Have you seen it work with another DAW? I had a quick look at the manual and it may look like you have to set up every control to send out. Have you done that. (I could be wrong on that) Using USB won't be using MIDI cables sorry As you can see in the OP I can get everything working, but I have to use two devices. It won't work with just one device (it's an either/or scenario), that's the root issue. Appreciated! @jpettit - Need to play catch up will check.
jpettit wrotehttps://forums.presonus.com/viewtopic.php?p=156319#p156319 Yeah good idea. So via monitoring I can confirm.. Controller events coming in channel 1 IN A-PRO2. Keyboard events coming in channel 1 IN A-PRO1. See (a) in OP. As for the rest will need to sleep on it. Thx.
jpettit wrotehttps://forums.presonus.com/viewtopic.php?p=156319#p156319 OK this was the trigger ^^ so thanks! SOLVED Although there could be a better way, this works. If you are an A300 user let me know. Anyway this is what I needed to do on the keyboard itself, hopefully this will help other users. Press ACT and "<" at the same time. Use the value knob until you see "SYSTEM SETTINGS" and select. Use the value knob until you see "OMNI" and select. Turn OMNI ON and select. (b) Will now fully work and I can delete (c). I'll probably wake up tomorrow and wonder how to do it without OMNI but it works right now. Appreciate everybodies help!
For the sake of completion/reference I'll paste the other stuff from the Sonar forums that was very useful.
Note though he does not set up OMNI mode so he is setting up two devices for one keyboard like I was, so see see my previous post on how to simplify this to one device. Thanks icontakt wroteHere you go!
Oh one more thing as Columbo would say.
I have a PAUSE button on this controller (part of transport controls). Does anybody have any suggestions as to what I should assign this with in Studio ONE? It's not altogether obvious as there seems to be no pause on the app itself for the transport. Thanks!
For the record, discussion of mapping B1, B2, B3, B4 here:
viewtopic.php?f=151&t=27955
PreAl wroteOh one more thing as Columbo would say. Answer is to assign a Macro as below thanks to adamthomas5: adamthomas5 wroteOne of the first macros I had to search for (how do people use a DAW without it?):
Here's an A300 Gotcha under Kontakt, whereby the volume will always be automated via S9.
viewtopic.php?f=151&t=28573&p=162062#p162062
Users browsing this forum: No registered users and 58 guests
