Some soft synths (e.g. Komplete, Garritan, and a few others) do not keep volume settings. This results in their sounds far too soft to be useful in a mix. I have not found the problem yet with Presonus' Presence sounds.
I tried to use Studio One's Macro's - they don't make a difference. Screenshot 1: Studio One Console view. Channel on far left is Presence. Note fader more or less in middle. The next channel is Garritan Aria - full blast, yet the sound is still too soft to use/ Far right channel is Native Instruments' Komplete. It must also be set very high to be heard. Screenshot 2: Garritan Aria strings. Volume setting is far right, third row of settings. While rolling, I can adjust it here, and then it sounds great. The moment I re-roll, it jumps back to its original setting. Screenshot 3: Komplete Volume is on far right, third row of settings. Notice it is about at a third. While playing, I can adjust it, but on re-rolling, it jumps back to this position. In previous music software I used, I could get into a MIDI editor and check of CC7 is set ok. I can;t find anywhere for this to be done in Studio One. Any suggestions on how to fix this? If it were only one plugin, I guess the problome would have been there; but several? Yet, strangely the Presence plugin is fine. |
That's acting like a midi track with a volume message in it.
This is a new track, not imported midi?
S1 faders are audio volume. To adjust CC7 add it as a controller in automation lane
Do you mean stored with the songs or on the fly?
Most likely you have something sending that CC7 signal. In my example using Aria player, it follows the Volume automation correctly. If I delete the automation it stays where I leave it.
Mine in the test was not resetting.
I suspect there is something else doing via a shared MIDI channel.
Users browsing this forum: AAV, larryjones8 and 35 guests
