Hi Studio One community,
the new maintainance update Studio One 3.5.2 is online! There is support for the new StudioLive III rack mixers and AR22 mixers. And furthermore a few nice workflow improvements for your daily work and bugfixes for more stability and flexibility. And we have a present for all Studio One Artist and Prime users: You get the Arranger Track! A real powerful tool to organize and/or remix your tracks. All the best Ari ______________________________________________ Version 3.5.2 Release Notes (September 26, 2017): New features and improvements: • Arranger Track in Studio One Prime/Artist • Support for StudioLive Series III rack mixers • Support for StudioLive AR22 mixer • Command for "Mono" in mixer main out • Click on automation track control opens the plug-in • Bounce keeps bus routing • Option to disable mixer undo • Updated Song Information window design • Blacklist for incompatible VST3 plug-ins • Delete device slots by drag & drop (with cmd modifier) • Higher resolution for zoom commands option • Improved Quick Zoom behavior • Favorites list in browser sorted alphabetically • [Project Page] Events snap to other events when moved or resized • [Project Page] Digital Release renders individual tracks based on track markers • [Developers] API for cloned plug-in instances in low-latency mode The following issues have been fixed: • [Fat Channel XT] gate won’t recall settings correctly • [Fat Channel XT] some remote controls missing • [Fat Channel XT] Macro Controls lose link to parameters • [Fat Channel XT] wrong scaling in Gate gain reduction meter • Wrong behavior of duplicated notes in triplet grids • No Level Meter peak reset in micro views • [macOS] “No device” not selectable in Core Audio input selector • [macOS, 32-bit] Audioloops showing unknown format won't play • [macOS] Crash when unloading certain AU plug-ins with GUI open • [macOS] Core Audio devices show one sampling rate only • Copy to new scratch pad + "don't follow" Tempo setting doesn’t place audio correctly • Send level parameter jumps at certain values • 3.5 Spectrum meter scale differs from 3.3.4 • Duplicating Arranger section doesn’t copy first note event • Arrangement scrolls when moving folder event to Scratch Pad • Auto-save version time stamps can be incorrect • Automation sometimes not applied during mixdown • [Windows] No support for I/O with disparate number of inputs and outputs using Windows Audio • Mono channels don’t respect Pan law in software low latency monitoring path • [Mai Tai, Presence XT] Gater preset not saved when plug-in is deactivated • Multiple crashes on Start and Quit • Audio input can fail after using native low latency monitoring • Automation not copied correctly to Scratch Pad • Pipeline as Event FX doesn't force real-time render • Audio in video player not muted (still playing) • Channel names on multi-out Instruments not restored correctly • Copy & paste of events + automation in Automation Track doesn't paste automation • Transform audio and back resets track delay • "Mixdown Selection" doesn’t exclude unselected events within the selection range • “Cursor follows edit position” doesn’t work when comping using swipe • Moving Arranger Section leads to unexpected results • Crash when removing Track with Lexicon MPX-i • [Channel Strip] gain reduction meters pause or stop based on channel selection or UI status • [Start Page] Song list not updated after moving user data folder • [Project Page] copying metadata to all tracks only copies artist name • Crash after loading certain MIDI files • Wrongly displayed midi quantization value • Note Events before first bar can’t be quantized • Metering displays inactive on busses with native low latency monitoring • Truncated text in keyboard shortcut dialog • Newly created Instrument Tracks in Folder not assigned to bus • Missing application settings after upgrade • Focus issue with Song Setup metadata field tabbing • Bus order in console not stable when moving tracks • Crash when switching record channel
Users browsing this forum: No registered users and 25 guests
