I made a little experiment. I put two sine oscillators with the same parameters each in a separated track. Then I put a "Scope" and a "Phase Meter" in the Master track in order to observe the output signal. I've noticed this strange behaviour: When I pan one track to extreme left or right I can see a phase shift of about 1/3 PI (my guess) between left and right channel. I was expecting to see that one channel has a signal lower than the other one, but I was expecting with the same phase, so two identical signals, but just with different levels. Maybe it's correct, but I cannot understand the mathematical reason behind that. I've attached a snapshot to clearify what I've done. Any opinion/explanation about that? Thank you. |
You are doing this test incorrectly. By using two tone generators. They wont be in sync. What makes you think they will be?
I have checked this with one tone generator only and there are no phase shifts from what I can see panning either Centre Hard L or Hard R.
Jemusic wroteYou are doing this test incorrectly. By using two tone generators. They wont be in sync. What makes you think they will be? A perfect illustration right there as to why competent, experienced professional test engineers get paid a pretty good living. |
Yes that may be just a fluke. With one test tone generator I can see no phase shifts. It would be pretty bad if there was a phase shift due to panning.
I have got a real CRO as well which can be dual trace. When I send the test tone generator direct out to a send and hence a physical output I can always see that as a reference. I can also monitor the main outs as well on the other CRO channel. NO phase shifts. You are chasing your tail here with two test tone generators.
@ the O.P.
If there * was * a phase issue invoked by panning, why hasn't there been multiple reports of this by users ? It would have been blindingly obvious to the many S1 users who run pro studios, without doing random (and erroneous) stuff (it is not testing) with two sine wave generators, before now. What you are doing is fundamentally flawed. You need a single stereo signal from a single source in order to demonstrate that you are starting from a point of absolutely no phase issues to begin with. |
Yes, I got it, if I bounce the two tracks I can see the expected behaviour.
Anyway I was not trying to imply that S1 has a wrong panning implementation (that I know it's a basic functionality), but I was wondering why my little experiment was not working... Now I got it, I was doing in a wrong way It's clear that different instances of tone generator are not in sync. Thank you. |
Which brings up another point. If there were multiple tone generators perhaps some form of syncing would be good but not overall a necessity.
If you want to get a test tone into multiple places at once, one has to be creative and use only one generator and find a way to distribute the audio around to multiple destinations. That will always ensure that the phase relationships will be correct.
Users browsing this forum: No registered users and 45 guests
