I am wondering if anyone has a tutorial (copy or video) on how to set up the Behringer XR 18 Air with Presonus Studio One 3 PRO... I tried before and could not get it to talk correctly but others have said it works and I would love to start using the unit to record mobile instead of just live mixes. I am running Mac OS Sierra (latest) on iMac Desktop and Macbook Pro laptop... I have Studio One V3 installed on both. I have Studio One working with my other interfaces but could never get the XR 18 to work right.
Anyone have suggestions? Thanks in advance!! |
What issues do you have? The xr18 is automatically detected by the Mac and should be available as an audio interface in studioone.
I couldnt get studio one to show any audio input... I could see on the XR software input.. but studio one didnt detect anything... just wondering if I configured something wrong... lol
As for a quickie, select the xr18 as the audio interface in studioone and then select the studiolive16 as the template.
The outputs on the xr18 defaults to the mixbuses so depending on how you want to use the outputs you may need to re-route the outputs for the daw to directly access those. This should be a good start...
I am home and I have it up ...I see signal going into studio one... but I have nothing coming out of the mains for output... in studio one
I am trying to configure the outputs now so I can monitor them |
I am wondering if you could post a video on the set up on you tube ...Behringer assumes I own a MAC and use logic ...
I would like to see the connection from the beginning to the end ...from input of a track to output of the monitoring of it. I bet that more then a few of us would appreciate this who are PC, Behringer xr18 and Studio One. If you or anyone else can talk me through it I would greatly appreciate this. Keith |
I have been trying to set up my Behringer XR18 with Studio One 3 Windows (SO3) for two months—with only partial success.
You first need to install the XR18 Windows driver in order for SO3 to recognize it. SO3 recognizes the XR18 as an audio input (XR18 USB out -> USB in on Windows 10 PC), we have mapped the XR18 channels to SO3 tracks, and we can record any of the channels. No problem. However, SO3 will not playback unless I change the audio input from the XR18 to Windows Audio. Only then can I play the recorded tracks. But then, I cannot record with the XR18 again until I change the audio input back to the XR18. PreSonus suggested I install the ASIO4ALL driver, which I did. SO3 does recognize the ASIO4ALL driver, and I can select the XR18 as the input, and Windows Audio components as the output. With the ASIO4ALL driver, I can now play the tracks, but it won't recognize the XR18 input. After not being able to get that working, this is what PreSonus support said: This is most definitely a Behringer with Studio One issue. Behringer does not have an ASIO audio driver. We have seen mixed results with their products. We have seen ASIO4all help with this, but we can't troubleshoot ASIO4all. So, if anyone has an XR18 successfully recording, with playback, into Studio One 3, please post here. OR, I will pay for consulting time if someone on the forum can successfully get this working. Karl |
I do not understand why presonus would say that the xr18 doesn’t have any asio driver. This is simply not true.
Go to https://www.music-group.com/Categories/ ... /downloads and download the “x air usb asio driver 4.11”. This ought to get you going.
snapnt wroteWill "Artist" record all 18tracks?? Ive been told only "pro" will Artist should record all 18 tracks. I am using the XR18 with 4.1 Pro without issues. If you can't hear it, it is probably because of a routing issue.
Studio One 5.1 Professional on Home built i9 10900K on ASUS Z490 Prime-A with 32 GB RAM 64-bit Windows 10 Pro Premium 500GB M2 WD Black SSD (OS) 1TB M2 WD Black SSD Data Drive. Behringer U-Phoria UMC204HD, and/or XR-18 USB 2.0 Interface. Single FaderPort , Behringer X-Touch control. Ozone 10 Advanced, Various Waves Plug-ins including Nx with Head Tracker and Ocean Way Nashville and Abbey Road studios.M-Audio Oxygen Pro Mini 32-Mini-Key Keyboard Controller, You Rock Guitar [Gen 2] Guitar MIDI Controller. Alesis DM10 MKII Studio Kit Electronic Drum Set.
Users browsing this forum: No registered users and 80 guests
