I have a 24 channel interface (iZ ADA) and using it with an SSL Matrix. The first 16 channels are connected to the SSL and I can insert analog gear via the SSL.
I use channels 23/24 as a print track. Channel 23/24 out are routed to the S1 MAIN channel. Everything is working as it should during playback.
The problem is when I try to get an Instrument to Bounce to a new track. I've only had S1 for a couple days, but last night I was able to get this to work. Today, I tried everything and I can't get the Instrument to bounce to a new track.
Anyone have a clue as to why this isn't working? I'd appreciate any help.
Thanks!
Studio One (latest version)
macOS (latest version) Mac Pro 3.0GHz (can)-64GB Ram (8 Core)
iMac 4.0 GHz, 5K, (Late 2015)-48GB Ram (4 Core)
SSL Matrix 2 - iZ ADA II, RME HDSPe MADI FX
by Dean on Tue Mar 28, 2017 9:25 pm
Anyone? PreSonus??
by Steve Carter on Wed Mar 29, 2017 3:20 pm
Hi Dean...
Not sure if you've had no response because of the terminology you're using or maybe I'm barking up the wrong tree - but....
Are you trying to 'transform' an 'instrument' track i.e. midi track with VSTi (or other software instrument) or an external hardware instrument?
In S1 to get a midi track to an audio track you're best to use the 'transform' function so that you can revetse the process at a later date if you want to make changes etc.
Sorry if I've got the wrong end of the stick....
Regards
by Dean on Wed Mar 29, 2017 3:45 pm
Hi Steve,
A few days ago after installing S1, and setting it up properly, everything worked. I clicked on 4 different "Instrument tracks" and the "Bounce to New Track" worked on all of them, even though their outputs were not set to MAIN. I can't get this to work anymore. I have used the Transform to Audio and Transform to Instrument and those work well, but why can't I get Bounce to New Track to work?
Thanks!
by Dean on Thu Mar 30, 2017 1:04 pm
BTNT isn't working unless the output is set to MAIN, which is ridiculous for anyone using a multi-output system.
by Dean on Thu Mar 30, 2017 1:42 pm
So what's the difference between Bounce Selection and Bounce to New Track? When I highlight an instrument track and try both features, they both create an new audio track right below the instrument track. This is normal?
Users browsing this forum: bartbalint, Lokeyfly and 67 guests
