When I right-click an audio track and select Edit with Melodyne, the following appears:
I'm expecting to see the audio signal spread over notes against a piano roll. How do I get the piano roll to appear? |
It may be that your version is the basic editor, and only has certain features. Without know what you have, I would verify that, and look on the Celemony website at the features comparison.
I have the full version 4.1. I sent Celemony a support request.
As a side, does Celemony depend or act off of connected MIDI devices? If so, I have a MPD24 plugged in, no actual keyboard. I've edited vocal pitch recently (like a month ago) on the same computer/system/installation. I can't figure what I've done to break it. |
Hi Adria,
No Melodyne doesn't act off of a connected MIDI device. It reads the edited audio file. I'm wondering about 2 things. 1. Had you ever had 4.1 working at all, or is this your initial first time using 4.x? 2. Is is possible, you either deleted the audio clip by accident? It's in your audio pool? [F10] You're correct. You should see a grid on even the basic Melodyne
I tried to see in an opposite approach if I could remove the notes, or piano roll at left. No can do.
I'm stumped but the fact that it was working a short time ago tells us you can get it back sooner than later. The grayed out area doesn't look right. Something's oing on there I'd say. Hopefully, the support you requested should come through.
Any solutions? I had a rough time just being able to activate Melodyne yesterday (actually don't even know how I got it but it was a back in fourth between Studio One and the Melodyne website) and after activation it was greyed out, I reset the plugins pool and worked fine after that. Today Studio One seams to be more responsive but now all of a sudden, Melodyne is not working anymore and all is greyed out like yesterday.
Adria S. wroteWhen I right-click an audio track and select Edit with Melodyne, the following appears: I am having this exact same problem. Use Melodyne Editor and algorithm options are greyed out but can change whatever the default is. It's so frustrating. |
Adria S. wroteWhen I right-click an audio track and select Edit with Melodyne, the following appears: Sorry for previous post. Have figured out the problem. You are in "Track Mode" - if you go to the options menu and select clip mode or note assignment you options will become available! Let me know how you get on! |
timspencer4 wroteAdria S. wroteWhen I right-click an audio track and select Edit with Melodyne, the following appears: I'm having the same issue everyone else is describing. Tried your solution but the options to change mode from Track Mode to Clip or Note Assignment Mode are also grayed out. |
Users browsing this forum: No registered users and 55 guests
