Hi.
Thinking about using S1 to score a short 10 minute video. However, no matter the zoom level or snap settings, I can't seem to get S1 to advance 1 frame at a time using the 'transport forward' key command (Numpad '+'). The smallest increment I can manage is 8 frames at a time using the shuttlepro (which simply sends the key commands). I can navigate to a frame manually by clicking in the timeline, but this is much less efficient than scrolling there via my shuttlepro.
In Logic or Cubase advancing a single frame via key command or with the shuttlepro (preferred method) works like a charm.
Any suggestions? I'd really like to give S1 a try in this context. Thanks in Advance for any suggestions.
aka "gesslr" or "george napier"
10 core iMacPro 1,1 | 64GB | OSX 10.15.6 | S1Pro 5.0.1 | MOTU I/O | Too Many Plug-ins |
http://www.storyaudio.com
FB: geo.napier3
PLEASE SUPPORT THESE FRs
Video follows edit mode
http://tinyurl.com/yc2gc9b3
Studio One Workspaces
http://tinyurl.com/ybgfjpoj
by nk_e on Tue Oct 18, 2016 10:47 am
A solution was posted in this thread by Bbd: viewtopic.php?f=213&t=14761
Copied below for convenience.
Bbd wroteHave you tried clicking in the sub frame field of the counter and then using your up/down arrow keys?
Excellent suggestion! That works and is a much better work around than holding the mouse down and attempting to scroll through the frames.
Until they provide proper support, this will have to do! Thank you.
FB: geo.napier3
by Bbd on Tue Oct 18, 2016 10:49 am
by Jemusic on Tue Oct 18, 2016 1:48 pm
Bbd actually means click on the 'Frame' window and adjust using up/down arrows. There are no actual sub frames visible in Studio One. A single frame is divided into 80 subframes. (Talk about fine resolution!)
It is not a bad workaround. That frame window does have to be in focus though. The second something else is in focus, the up/down arrows will do something else.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro
by Lawrence on Wed Oct 19, 2016 6:00 pm
Hi nk_e.
You can move the play cursor forward or back one frame at a time with macros. Set the timebase to frames and run this macro ...
- Create Range from Cursor
- Move Range
- Locate Selection
- Deselect All
Change the second step to Move Range Back to go in the other direction.
by nk_e on Thu Oct 20, 2016 8:10 am
Lawrence wroteHi nk_e.
- Move Range
- Locate Selection
- Deselect All
THIS IS PERFECT!!!!!!!!!!
Thank you Lawrence!!
FB: geo.napier3
by Lawrence on Thu Oct 20, 2016 11:11 am
You're welcome.
I pretty sure that's been posted here on the forum here somewhere a couple of times before. It's a good alternate way to move the play cursor around in general, using ranges much like clips, creating them and moving them around and then locating to them, so that approach is useful in some other scenarios.
by nk_e on Fri Oct 21, 2016 12:19 pm
Lawrence and Jemusic
Another quick question: Are we able to lock tracks/events yet ... another term used is "lock to SMPTE". There is a workaround here: http://forumsarchive.presonus.com/posts/list/42065.page
This was posted 4 years ago and I wonder if things have progressed.
I ask because I want some things locked to the movie and smpte position regardless of tempo changes.
Hope that makes sense.
Thank you.
George
FB: geo.napier3
by Lawrence on Fri Oct 21, 2016 12:40 pm
If you mean a clip at 0:05:30 or whatever staying at that time position even if you change the tempo, yes, set the track to "Don't Follow" in the Inspector.
It's a track level setting though, not a clip level setting. All the clips on the track will do that or not, there's no way I know of to make clip A do that while clip B on the same track doesn't.
Follow = Follow the timeline position (stay at Bar 2 or whatever as the tempo changes, but don't stretch)
Don't Follow = Hold Current Time Position (time-wise, of course the bar position will change if the tempo changes but it will still be at the same literal time position in hours:minutes:seconds frames, samples )
Stretch = Stretch to match tempo.
by nk_e on Fri Oct 21, 2016 12:44 pm
Lawrence wroteIf you mean a clip at 0:05:30 or whatever staying at that time position even if you change the tempo, yes, set the track to "Don't Follow" in the Inspector.
Follow = Follow the timeline position (move and stay at 1:00 or Bar 2 or whatever as the tempo changes, but don't stretch)
Don't Follow = Hold Current Position (time-wise, of course the bar position will change if the tempo changes but the it will still be at the same literal time position in hours:minutes:seconds frames, samples )
Thanks for your help Lawrence. I should have dug a little further. Sorry to bother you.
FYI I decided to take the plunge and try to score a 10 minute film in StudioOne. I had started the project a few days ago in Logic, but I have the luxury of a little extra time on this one so it's a great opportunity to learn by doing.
Thanks again.
FB: geo.napier3
by Lawrence on Fri Oct 21, 2016 12:52 pm
nk_e wroteSorry to bother you.
Not a bother at all my friend, happy to help. But yeah, all of that stuff is in the manual. Good luck with your film score.
by nk_e on Mon Sep 17, 2018 4:03 pm
- Move Range
- Locate Selection
- Deselect All
Hey Lawrence!
I hope this finds you doing well.
This macro seems like it is still the only way to advance/rewind a single frame of a video at a time. However, I think they have made a change since you suggested this...perhaps we have sub-frames now? I say that because this macro now advances the video veeeerrrryyyy slowly. Lots of spins of the shuttler jog dial now to advance a single frame. Just wondering if you find this to be the case also.
Would the fix be to modify the macro to execute the second command multiple times, or is there something to do in the first step (range creation).
I hope this makes sense. Cheers man!
G
FB: geo.napier3
by davedunbar3 on Sun Nov 10, 2019 2:12 pm
Hi NK_E
You are correct.
On Shuttle pro I used the run macro command and repeated the keystroke 34 times! Now it works.
Users browsing this forum: bruceqld, lhansen and 41 guests
