Delete unused Bounce files.
Posted: Fri Oct 14, 2016 5:54 am
by chilly7
How to delete unused bounce files? I use convert track to audio pretty oftten with ability to go back. And i might do it few time for a singel tack until i get results i want. Because i use the best quality and CPU cannot handl that load real time.
For Mac OS Sierra. (Do not know about Windows).
If do this way then you wont be able to conver back tracks which contain recorder audio to original state.
On the Song Menu, select Remove Unused Files.
check box "Delete Files permanently".
click"Yes".
BUT IN THIS WAY YOU CAN. Presonus must make this more easier but for now use this method.
The previus method which i used befor Mac OS Sierra does not work in Sierra but this one works.
But do it at you own risk.
Copy "Media" folder and put it somewhere.
Open the song.
click"Yes".
Then exist song with out saving.
Put back "Media" folder from somewhere to original location by replacing.
Then open song.
And you will see are dialog that some files are missing.
Select all of them and delete them.
Save song.
End.
