Hi there,
I hope for month that it gets solved friom update to update. S1 hangs for about 10sec on "Starting MIDI Engine". I disabled the service "Windows Midi Support" and bang. S1 startup finshed in about 1 sec (like S1v2 used to be) I removed all my devices from the surface data folder. But even with a complete blank list it still hangs. Running a SSD so speed should't be a problem. I start S1 really often so its important to get quick access. What can I look for?
PC: Intel i7-3770 4GHz | Asus P8Z77-LX | Corsair Vengeance LP 16GB | ASUS 960 GTX 4GB | Nesteq ASM-X Semi-Silent | Crucial SSD | Sasmung Spinpoint | RME HDSP 9632 | UAD-1 | WIN 10 Pro 64bit
DAW: S1 Pro 4 | Ableton 10 Suite | FL Studio 9 (hate the way they changed the piano roll in the new versions) Hardware Synth: Clavia Nord Rack Monitoring: GENELEC 8040A / Focal Shape 65 / Auratone (full threated room) | Own Mod Headphones (best / flattest Headphone on planet) Benchmark DAC1 USB | Mackie Big Knob |
This is a known problem with v3.3.0. They're currently working on it. I have the same issue. Studio One v.3.3 seems to have compatibility problems with number of MIDI drivers. (Re-)Install the previous version, v 3.21 for now.
Elson Trinidad Los Angeles, CA, USA
Web: www.elsongs.com Twitter: twitter.com/elsongs DAWS: Presonus StudioOne 3, Cakewalk Sonar Platinum, Propellerhead Reason 9 OS: Windows 10 CPU: Intel i7 3820 3.6MHz MB: ASRock X79 Xtreme4 RAM: Corsair Vengeance 16GB DDR3 Audio: Focusrite Scarlett 18i20 2nd Generation MIDI: M-Audio MIDIsport 4x4; M-Audio Axiom 61 |
have you guys installed v. 3.3.1?
Guitarist and composer:
---------------------------------------------------- https://itunes.apple.com/it/artist/davi ... d968493291 My system: ---------------------------------------------------- MacBook Pro i7, 16 GB ram Presonus Sphere |
dr4kan wrotehave you guys installed v. 3.3.1? Yes. As always I check the changelog and was hoping it got solved after reading it or at least got a bit better. 3.3.1 does seem to load the vst serives faster than previous releases. Its not an urgend problem so I don't want to raise a support ticket and I thought I got a screwed midi driver maybe.
tshadgett wroteI'm seeing this behaviour now on 5.02.60299. Only just started on this machine when loading it up today... Same thing just started for me on 5.2 |
Users browsing this forum: davidlarson6, stephenboyke1 and 45 guests
