Does not see my network
Using 192 studio one and pc windows 10
I am the KLOPS
http://WWW.KLOPSDRUMS.COM The only HD guitar cabs on the Planet Dual 23 inch HP TOUCHSCREENS 2.2 AMD 4 GIGS Ram windows 10 192 AND STUDIO ONE using 2.2 AMD with 8 GIGS Ram windows 10 |
Did you follow the steps outlined in this POST?
Michael Morgan | pearl hour project --------------------------------------------------------------- Intel i7-2600 @ 3.4GHz | 16G ram Windows 10 | Studio One v3.3.1 | Live 9.6 (all software 64 bit) RME Fireface UFX | Nektar Panorama P1 | AKAI MPK25 | M-Audio Keystation 88 I Maschine 2 | Fader Port 8 |
Yes...
Remote says..I don't have the correct studio one.. It does not support my version of studio one
I am the KLOPS
What version of S1. I would also check firewall and make sure studioone.exe has an exception, and make sure the network setting in S1 preferences allows remote connection.
Even though the message references a version, 9 out of 10 times its a network issue |
Just as a heads up, if you have VirtualBox installed on your Windows machine, you must take the following steps (found on an older thread), or the remote will never find Studio One:
Workaround - I've suggested they add a note about VirtualBox to the flow chart, as it's a complete show-stopper unless you know about the fix. |
it scans and sees s1 remote but error is not supported with my version ...i have s1 that comes with studio 192..
I am the KLOPS
And the version of Studio One that came with your 192 is? If it came with Artist it is available as an add on, not available for Prime and comes with Pro. To me, this sounds like the issue.
Kind Regards Skip
Skip
Yeah...it's artist....
So yes or no with remote??? And I would need to upgrade to pro for remote to work
I am the KLOPS
With Artist you will need the add on. Cheap. Here's a link https://shop.presonus.com/products/soft ... te-Support
Enjoy, Klops Skip
Skip
Ssssaaaaawwwweeeeeettttt..
That's fabulous...
I am the KLOPS
Ok bought the add on...also created a ticket..
I downloaded the install but ..can't get past that.. Windows 10...it wants to open the file in a browser..
I am the KLOPS
Nevermind, all set..everything is ok..
Installation was on wrong pc.. But studio one remote..is working.. Awesomeness.....
I am the KLOPS
Skip
It should be, but with more scrolling due to screen size. I would just download it, as the app itself is free. The only cost on the app, is if you are using Studio One Artist. If you are, then you need to purchase the add on for Artist in the Presonus shop at about $10 usd.
However, you don't need the add on to download and see the app, so try it first and see if its ok. Should work in demo mode |
Users browsing this forum: jazzundso, patrickviens, wolfgerb and 28 guests
