Hello !
Wondering if it's a way to remove all time signature changes in the arranger track, moving parts around the project really messed up everything (quite sure due to a bug in the software). Please, please, please don't tell me i need to go by hand and remove them individually ! |
Hi Matt. There doesn't appear to be a way to select them all at once, no.
Try this... 1. Select everything in the song, all clips and automation, etc. 2. Drag it all to a new empty scratchpad, directly, not via Arrange markers. 3. Go back to the main timeline, draw a selection range across the entire space and Delete Time which should remove all of the time signature markers. 4. Put the other clips back there. Or, if there are no clips there yet like in your picture, just Delete Time. |
any solution for this bug,?
I was moving around some parts with time signature changes in a project and ended with a bunch of bogus extra time signatures all over the place |
karnellrobinson wroteRight click on timeline. Then click on loop follow selection. Drag the other marker to the end where you want the time signatures deleted. Right click on the timeline again then click delete time in loop. All the time signatures should disappear. Thank YOU! I WAS SO CONFUSED. This actually highlights a dope feature. |
