See this thread for this issue viewtopic.php?f=151&t=25825&start=20
This is driving me nuts...I've only noticed it on this one song. I listen in my studio...it's fine. I export a mixdown and copy it over to my phone for listening on earbuds and in the car and much of the automation work is not being followed.
The mindblowing thing is that it's not consistent. Sometimes the export follows the automation just fine. Other times, some of the automation is followed and some other tracks aren't. I just exported a mixdown, copied it to my phone and only one track wasn't following the automation. So I physically deleted the audio and re-exported. Now a few other tracks automation is not being followed in this export. And I've triple checked the instruments and the automation (all complete cuts of the volume) and they're just as I expect. And they're just as I hear when I play it back in the DAW. But exports of this one song are driving me nuts.
Has anyone else run into anything similar?
I'm on 3.2.0, 64-bit, Windows 10 and merely automating volumes, although my latest "test" results in a delay send not following the automation as well now that I've just deleted the audio I was previously automating.
by se19an79 on Wed May 18, 2016 10:03 pm
I'm having this exact same issue...I keep restarting Studio One hoping it will start working, but with no luck. In my case, no matter what I do I cannot get the automation to bypass insert plug-ins to take place in the exported file. It works fine in the project, just not at mixdown. Not sure what is going on...
I'm also on 3.2.0, 64-bit Windows 10.
by talanarney on Mon Jun 20, 2016 9:13 am
se19an79 wroteI'm having this exact same issue...I keep restarting Studio One hoping it will start working, but with no luck. In my case, no matter what I do I cannot get the automation to bypass insert plug-ins to take place in the exported file. It works fine in the project, just not at mixdown. Not sure what is going on...
I'm having this problem on the latest version of V3, I cannot render my music out because of this.
by eddieruff on Wed Jul 27, 2016 9:18 pm
Same here. This is very frustrating. I hear the automation exactly as I want, and then the export is completely wrong.
by stefanwalcott1 on Thu Feb 09, 2017 10:16 am
Same here guys!!!!! I will try updating my version now.
I am glad it is not just me. :roll:
by joswylin on Thu Apr 06, 2017 9:39 am
Exactly the same here.
In an orchestral score, the Viola-1 doesn't respond to the expression automation anymore. It started to do so a couple of days ago. But not only when performing a mix down, also during playback.
I had a similar issue with some key switches not being 'read' by S1.
Pretty annoying and my work should be ready by now...
I work with S1 v3 pro and VE Pro with the VSL library (36-part score). Only the violas are being contrary... The rest is just doing fine. :x
by jasoncogswell on Fri Jun 23, 2017 9:19 pm
Has anyone figured this out yet? I'm having the same issues on several songs. In 3.3 and 3.5. It'd be great to hear there's a fix. I submitted a ticket with a song file bit so far no luck.
S1 3 PRO 64bit, Win 10 64bit on dell xps8900 i7 16gb, Glyph studio raid 6tb Sceptre S8 monitors, temblor t10 sub, Faderport Studio 192 + 2 dp88's, 2 Warm WA-412's
by JulianK on Sat Jun 24, 2017 11:11 am
I have the same or at least a similar issue, but only ever since 3.5.
Here's my issue viewtopic.php?p=142284#p142284
and here are 2 other similar threads
viewtopic.php?f=151&t=25825&p=144443#p144443
viewtopic.php?f=151&t=25745&p=144445#p144445
Windows 8.1 64-bit (6.3, Build 9600),Processor: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (8 CPUs), Memory: 32768MB RAM, AudioBox 22VSL
by jpettit on Sat Jun 24, 2017 11:14 am
jasoncogswell wroteHas anyone figured this out yet? I'm having the same issues on several songs. In 3.3 and 3.5. It'd be great to hear there's a fix. I submitted a ticket with a song file bit so far no luck.
Please give more information on 3.5.
Consistency: Every song? Some songs? Some tracks?
Length of song: 1-4 minutes? 10-20?
Rendering: Realtime? Non Realtime?
Where in the song?
The community needs to get close to a pattern to report it otherwise it will not be fixed.
Thanks
by jpettit on Sat Jun 24, 2017 11:15 am
JulianK wroteI have the same or at least a similar issue, but only ever since 3.5.
Thanks I will consolidate them.
Actually this was was old and did not have enough info to repeat so I am going to consolidate the other two and move your post there.
by jpettit on Mon Jun 26, 2017 11:18 am
Move last thread to here viewtopic.php?f=151&t=25825&start=20 an locked this one to consolidate posts on the issue.
Ari (development) needs a song zipped up and sent to him to try to see the issue as not one has been able to replicate.
Thanks
Users browsing this forum: No registered users and 41 guests
