Just started using Audiobox itwo with Studio 1. The problem is latency when when playing guitar with the Monitor engaged. If I turn the monitor off I can hear the guitar through the headphone output. I've put the Ampire plugin on the track insert but can only hear the result with the monitor clicked on...then there is a delay between strumming and what I hear. I've gone into Audio Setup and tried setting different internal block sample sizes but the input latency always shows 51.07ms and the output 62.09ms. Process precision shows 32 bit. Sample rate 44.1Khz Bit depth 32.
I'm using a laptop with Windows 8 64 bit Intel i3 2.4Ghz 8Gig Ram. Until I get this sorted I can't use it....Help Please! |
On windows you need to decrease the size of the buffer in the AB driver control app. Reducing the buffer size will reduce the latency, but increase the load on the cpu. It will be a balancing act if the pc is not up to the task. There is a lot going on in the background, so pure pc specs may not be the tell all for performance.
As a way to check the system, you can download latencymon, its a freeware app that you run with the AB hooked up, and it will give you reporting on the pc's ability to handle real time audio processing. |
matthewgorman wroteOn windows you need to decrease the size of the buffer in the AB driver control app. Reducing the buffer size will reduce the latency, but increase the load on the cpu. It will be a balancing act if the pc is not up to the task. There is a lot going on in the background, so pure pc specs may not be the tell all for performance. Hi! I just came across this thread, and I follow what you are saying, but I can't figure out how to adjust the buffer size in Windows 10. Any guidance would be most appreciated. My specs are pretty close to the OP, block size 485, input latency 44, output latency 22, with dropout protection at minimum and 32 bit precision. Thanks! Giselle |
Welcome to the Forum!
The settings in S1 should change your interface as far a block size etc. The line that shows the device block size is a dropdown. The numbers there reflect the capabilities of your interface. Some interfaces go really low and some don't. The M4 I have can go down the 16, some go down to 2. I use a block size of 128. https://s1manual.presonus.com/#Setup_To ... 257C_____2 Mine doesn't have a dropdown but it has a button for the control panel, I can change the sample rate and block size there in the controls for my interface. Good to put your specs in your signature, click below in my signature.
Users browsing this forum: No registered users and 97 guests
