Can you route an audio track to another audio track?
Posted: Mon Jul 28, 2014 2:11 am
by davedurr
Just wondering if that was possible and if not, is the only way to bounce 2 tracks into only 1 track by soloing the 2 tracks and rendering the master bus audio?
Re: Can you route an audio track to another audio track?
Posted: Mon Jul 28, 2014 11:42 am
by davedurr
niles wroteYou can't route an audio track to an audio track. But you can route audio tracks to a bus and use that bus as an input for an audio track.
I only see Inputs, not buses as options for routing into audio tracks. How do you do it?
Posted: Mon Jul 28, 2014 11:45 am
by matthewgorman
The track needs to be stereo that you are routing to. When you configure a new stereo track, at the top of the channel fader lists the inputs, click the black box and select the buss as the input.
Posted: Mon Jul 28, 2014 11:49 am
by Kiwicomposer
Posted: Tue Jul 29, 2014 7:29 am
by codamedia
matthewgorman wroteThe track needs to be stereo that you are routing to. When you configure a new stereo track, at the top of the channel fader lists the inputs, click the black box and select the buss as the input.
I always record mono tracks so I never knew this was possible. It's so easy to convert a stereo track to mono it's a non-issue. I will keep this in mind for future reference - thanks.
Posted: Tue Jul 29, 2014 7:40 am
by matthewgorman
Hopefully at some point we get mono busses.
Posted: Tue Jul 29, 2014 11:05 am
by Lawrence
Yeah, mono busses would be nice.
Jeff suggested something long ago that sounds more like a workaround than it is but may be a good solution in some cases. If you have S/PDIF and don't actually use it for anything, just loop it, patch the output back to the input.
That way you can directly realtime record any mono track back to a mono track directly with no conversion. Just don't create a feedback loop if you do that.
Posted: Tue Jul 29, 2014 12:20 pm
by sunmachine
LMike wroteJeff suggested something long ago that sounds more like a workaround than it is but may be a good solution in some cases. If you have S/PDIF and don't actually use it for anything, just loop it, patch the output back to the input.
With some Audio Interfaces you can even set up an internal loopback routing so you won't need real cables. Have to try this with my Fireface UCX some day. I guess that should work.
https://www.youtube.com/watch?v=i6PTnFo0cfQ
+1 for mono busses, though. What you already can do now by the way, is to record the output of mono VST Instruments to mono audio tracks.
