I use Windows OneDrive which requires access to the Documents folder as well as all subfolders within. OneDrive wants to sync frequently. However, Studio One always does frequent saves. While working on a project in the Project page, if I click on a song that needs a minor change in its mix, when S1 goes to fetch the song it reports that 'there is a newer version...'. That is not really true. I think it just sees the time stamp from the most recent autosave. Confusing and annoying.
MS OneDrive will not allow any folder under Documents to be exempt from sync.
Is it really necessary to have Studio One under Documents? Can't it just be in its own folder an the root of some other drive ('C' for example) ?
Studio One 6.1
Studio Computer 'A': - Dell XPS 8700 Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz 3.60 GHz
Win10 22H2 12gb RAM, 1TB HDD
Studio Computer 'B': - Dell I5-13400 13th Gen Intel(R) Core(TM) i5-13400 - 2.50 GHz. 16GB RAM, 256SSD, 1 TB HDD
Presonus StudioLive 16.4.2
by Tacman7 on Mon Sep 18, 2023 4:06 pm
Welcome to the Forum!
Studio One allows you to save a song where ever you want to put it. You set it when you create the song, or save to new folder from inside a song.
Studio Computer - Nectar Impact LX25+
Win10 i7 7700k 16gb ram 1TB SSD AsusH270M-PLUS interface:StudioKonnekt 48
Kitchen Computer - Microkey Air Eris 3.5
Win10 Ryzen 5 3600 - Radeon RX 590 - 512GB SSD interface: Motu M2
Kitchen Audio Mac Mini M1 Apollo Solo
by BobF on Mon Sep 18, 2023 4:33 pm
Go to Options>Locations and set a path to where you want your files saved
Studio One Pro - latest / Win10Pro x64 (latest) / i7-6700 @3.8Ghz / 32G / UMC1820 / Event PS8
RC w/Galaxy S7+ / KKS61MK2 / Atom SQ
by politepatrick on Mon Sep 18, 2023 4:39 pm
Tacman7 wroteWelcome to the Forum!
Thanks! Will do.
I understand that the 'Song' folder can go anywhere. Can the entire 'userdata' be put anywhere as well? I think there is also a 'song' folder as a subfolder in userdata, no?
Studio One 6.1
by politepatrick on Mon Sep 18, 2023 4:40 pm
BobF wroteGo to Options>Locations and set a path to where you want your files saved
Thank you for your reply!
Studio One 6.1
by Tacman7 on Mon Sep 18, 2023 5:57 pm
Yea when you set user data up in locations then that would be your default location but you can change that to a different location for the current song if need be.
by Vocalpoint on Tue Sep 19, 2023 5:42 am
politepatrick wroteI use Windows OneDrive which requires access to the Documents folder as well as all subfolders within. OneDrive wants to sync frequently.
In addition to the solid advice on where to store your S1 user data - please note there is no requirement to have the Documents folder (Windows) being exposed to One Drive at all.
I use One Drive here as well - but never allow One Drive to access Desktop,Documents or Pictures folders as default. One Drive has its place but not to copy everything on my drive.
Like others have noted - you should never allow S1 to write to any location where One Drive will be copied things and altering file stamps etc.
Cheers
VP
DAW: Studio One Pro 6.2.1.94935 | Host OS: Windows 10 Pro 22H2 | Motherboard: ASUS ProArt z490-Creator | CPU: Intel(R) Core(TM) i5-10600K | RAM: Corsair Vengeance LPX 64GB | Graphics: Intel UHD 630 (HDMI) | Audio Interface: RME UCX II (v1.221) | OS Drive : Samsung 970 EVO+ (500GB) | Media Drive: Samsung 860 EVO (500GB) | Storage 1 : Samsung 970 EVO+ (2TB) | Storage 2 : Seagate FireCuda (2TB) | Monitoring: Presonus Monitor Station v2 + Presonus Eris 5 | MIDI Control: Native Instruments Komplete S61 & Presonus ATOM
by politepatrick on Tue Sep 19, 2023 1:44 pm
Thank you for this input. How did you get OneDrive to exempt Documents. I tried that and the lovely software kindly advised me that was a 'System' folder and could not be exempted!
Studio One 6.1
by Vocalpoint on Tue Sep 19, 2023 1:52 pm
politepatrick wroteThank you for this input. How did you get OneDrive to exempt Documents. I tried that and the lovely software kindly advised me that was a 'System' folder and could not be exempted!
Try this:
Click the One Drive icon in the tray and go to the little "gear" in the upper right of the menu that flies out.
Click Settings->Sync and Backup->Manage Backup.
Dump the folder targets you do not want (see graphic)
Cheers
VP
by politepatrick on Tue Sep 19, 2023 7:07 pm
Try this:
Holy Cow! That approach worked -- even though it stands in direct contradiction with the other approach.
Thank you VERY much for this very useful tip!.
Studio One 6.1
by Vocalpoint on Wed Sep 20, 2023 5:43 am
politepatrick wrote Holy Cow! That approach worked -- even though it stands in direct contradiction with the other approach. Thank you VERY much for this very useful tip!.
Patrick - you are welcome! Glad I could help.
VP
Users browsing this forum: Tacman7 and 47 guests
