Hi all.
I found the transpose function (thanks Joe Gilder video) and transposed my guitar for fake-bass. I don't know what I did but now the inspector only shows: Start End Play Mode Stretch Events Time Lock Edit Lock in the bottom panel of all my audio tracks. All my midi tracks have: Start End Synch Point Transpose Velocity Time Lock Edit Lock. If I create a new audio track, I do have transpose back, but if I copy/paste from existing audio (to pitch shift for harmony) I don't have Transpose. I have put the old audio track through Melodyne. Is this the issue? Cheers
Studio One 6 (latest update) Professional, Atom SQ, Komplete S88 Mk2, Komplete Audio 6, KRK Classic 8s, Melbert Deluxe 8 string Lap steel with Artist Tweed tone 20R amp, OLP 5 string "Music man" bass with Marshall Dynamic Bass System 200w amp and Marshal DBS 4 x 10 cab, Rode NT1A mic, Dell XPS8950 12th Gen Intel(R) Core(TM) i7-12700K 3.60 GHz, 16.0 GB (15.7 GB usable), 64-bit operating system, x64-based processor, Windows 11 Home, Komplete 14 Standard, Izotope Neutron 4, Ozone 10 Standard, Ayaic Mix Monolith, Sonar Works SoundID Reference. "All the gear .... no idea"
Odds are high that one of the files has the customization settings differently, so some options are hidden right now.
With the file open where you have the missing info try the following: From the menu: "View > Customization > Edit Customization..." [EDIT: If you have the Inspector open, right-click and "Customize..." is available via the context menu. "Customize..." is also available in other right-click context menus too... I can't track them all...] Change to the "Inspector" tab, then look to see what is hidden (no check mark). At the top, change among the Active Customization options when the file is open (yours is probably NOT on "Complete"). "Complete" will display all options, but try the other dropdown options to see what is shown/hidden, and again, my guess is your display was on one of the others. Later you may want to customize some of the sections yourself, and you can name/save a customized view of your own. If you right-click in the spaces in the main toolbar at the top, you'll see a "Customize..." context menu, and it gets you to the same "View > Customization" dialog box. Same in the bottom, anyplace you find "Align" you'll also see "Customize..." They have sprinkled it around the interface...
Last edited by donaldbaarns on Sat Jun 10, 2023 11:21 am, edited 3 times in total.
Don
S1 v6.x Pro - latest version PreSonus Studio 26, IO 24, Atom Eris E5s iZotope RX10 Advanced Win 11 Pro-32GB RAM-AMD 3900x AMD 5700XT Windows 10 Pro-16 GB RAM MacOS Ventura (13.4) iMac i5 w 8 GB RAM FB group: Studio One Users-Audiobooks, VO and Podcaster focused: https://www.facebook.com/groups/StudioOneNarrationVO/ Studio One and iZotope RX Courses for Narrators/Podcasters/VO: https://www.VOJumpstart.com/ Studio One and iZotope RX Videos for Narrators/Podcasters/VO: https://www.youtube.com/user/RedBaarnsAudio |
michaelhill31 wroteHi all. Yeah I noticed this too. If you ctrl/right click on the region, there’s a transpose option in the pop up menu. Just started happening with certain regions in the last update. Just figured they moved it for some reason.
Studio One Pro 5.5, Studio One Pro 6.12, Faderport 16, Faderport Classic (1.45), Metric Halo ULN-8 MKIV, Presonus Quantum, Presonus Quantum 2, Ferrofish Pulse 16, (2) Digimax DP88, Audient ASP800, BLA HD192, 27-Inch Late 2012 3.2GHZ i5 32 GB 1600 DDR3, 2Tb SSD, 10.13.6 High Sierra + 10.14 Mojave + Windows 10
Hi everyone
Thanks for your replies. Everything is turned on in Customize (set as "Complete" with everything checked). As an experiment, I just created a new "Test" audio track in the same song. "Transpose" is available (as well as a ton of other options, many of which I don't have on any other tracks,) including: A white box that says "Clip Version" if hovered over (beside the track name) Event FX Start Finish Sync Point File Tempo Speedup Transpose Tune Normalize Gain Fade-in Fade-out Bend Marker Threshold Gain Envelope Time Lock Edit Lock. I did the same process as the other audio "fake-bass" track (I'm pretty sure) including: Transpose -24, Detect Transients, quantize (being lazy with "bass" timing), and running through Melodyne Assistant. After doing that everything is still available on the Test track that I just created, but none of the audio tracks I made previously have Transpose (or any of the extras) available.
Ah, I see. It seems you confused tracks and events. You said track but you actually mean event.
The events are the elements in your arrangement that you place on a track. A track can contain several events. The bottom panel in the inspector is for the event, the upper panel is for the track. The problem here is most likely that you have merged your audio events. The result is an Audiopart (container that combines different audio evens). Audioparts don't have the same properties (Transpose, Tune, Gain Envelope) as the single events. You can recognize an Audiopart by the chain symbol. One solution is to double-click the event to open the Audio Editor and edit the original events inside of the audio part. The other solution is to dissolve the Audiopart to get the original audio events back. I made this video that explains what Audioparts are and shows some possible solutions on the issue you describe: I hope that helps!
Lukas Ruschitzka
Studio One Specialist Advanced Studio One Tutorials || Free Studio One Scripts || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ] Core i7 3.24 GHz, Windows 10, 24 GB RAM, RME HDSP 9632, PreSonus FaderPort, PreSonus Monitorstation, PreSonus Eris 5 Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate |
Brilliant, thanks Lukas.
The event had been merged. I’m fairly new to Studio One and I was using the incorrect terms and calling an Event a Track, thereby confusing those trying to help me. Regards Mike
michaelhill31 wroteBrilliant, thanks Lukas. Super cool Lukus realized what you were doing, I missed that! It didn't occur to me that someone might have Merged Events in this context. Just a side note: Screenshots would have made it 10x easier for us to see the issue quickly. S1 has so many options, and details matter when figuring out what someone is doing. Lucus and/or others in this group would have immediately seen the icon in the lower-left corner of the Merged Events (an Audiopart) and I suspect would have nailed it much earlier. If you can post screenshots, you can get more targeted answers from so many who want to pay it forward and assist. (You use the "Upload attachment" tab below the editor to add shots... and can place them "Inline" after you upload. Dated interface, I hope someday they update this board, but another topic for another day...) No stress either way, but posting visuals will get you quick answers that are more likely to solve your specific issues.
Don
Wait, mine is really gone until I ctrl+click on a region. I’m gonna figure this out.
Users browsing this forum: No registered users and 54 guests
