I am new to recording with studio one. I have 4 volumes to set: the audio interface channel volume the audio interface master volume the studio one track volume and the studio one master volume. I need some very basic advice on setting these levels to get the best recording. Thanks
pauldavidson7 wroteI am new to recording with studio one. I have 4 volumes to set: the audio interface channel volume the audio interface master volume the studio one track volume and the studio one master volume. I need some very basic advice on setting these levels to get the best recording. Thanks Paul Welcome to the Forum! Q: What audio interface are you using and what exactly are you recording coming in? In Studio One - suggest you always leave the track faders AND master bus fader at 0.0dbFS. For your audio interface - adjust your input channel gain to be just hot enough to prevent any red lights from flashing (Or whatever your I/O does to indicate a "too" hot signal) In S1 - for each single track you add (except possibly drums) - shoot for your input to tag up anywhere between -18bFS and -12dbFS. Anywhere in that zone is great for gtrs, bass, keys , loops, vocals etc. You also have finer control with the Input Gain controls in the S1 console to ensure everything is nicely in the pocket before recording anything. For drums - same general zone but it's OK to have the occasional snare drum or transient hit pop up to -10dbFS or even -6dbFS for an instant. Compression is your friend to tame the drum kit. Bottom line is ensure that all channels - especially the master bus - do not approach or exceed -0.1dbFS. If you see a small red box at the top of the master bus meters with numbers flashing after laying down a half dozen tracks - you have gone too far and are now clipping the overall mix. Left unchecked - this leaves you with a file that generally will sound nasty. Good luck! VP
Users browsing this forum: BobF, steveevans1968, Tacman7 and 87 guests
