https://youtu.be/n3vRuJxCHk8
same like REAPER ,or Cakewalk can do, i need to do for Superior Drummer . |
Sorry, just a feature of V6, right click on pan slider:
vincentcool wrotehttps://youtu.be/n3vRuJxCHk8 Split option,Channel Split in the pic below. This is the easiest way for duel mono. You can also drag audio to the browser, right click for options and use split file to left and right mono then drag them back in. The only problem is at least to my knowledge you cant route to a mono channel after you split them it always outputs the left and right split to a stereo out channel. If you bounce to audio and split to left right mono you can do mono channels np.
This may help depending on your end goal for the mono tracks.
https://blog.presonus.com/2021/01/22/pr ... tudio-one/ |
https://drive.google.com/file/d/1PEkhg2bShG3n_7YW7FWgxPdE9tvnJQYk/view?usp=sharing
here is my Superior Drummer 3 Multi mono output, i make this 2021 year using S1 5 ,but is not a good way to do this,abit mess... if can split stereo vst output to mono ,is good for mixing drum toontrack etc... and is sad cant use S16 Track Presets,recall is wrong... |
Users browsing this forum: No registered users and 80 guests
