When using Song View is it possible to have two seperate MIDI controllers control two separate tracks at once? I cant seem to get it to work - tried setting up my two controllers on two different midi channels but it will only control the track that is currently focussed/highlighted.
Or is the only way to do it on the Show Page? |
Welcome to the Forum!
I can direct inputs by channel coming into a track from a plugin. I'm not able to stop live input from playing by changing the channel. If you want multiple simultaneous inputs you need a multiport midi interface. Or different midi ports, like maybe one on your interface then a usb controller would be a different port. Good to put your specs in your signature, click below in my signature.
Both instrument tracks need to be input monitoring. There is one other thing though. Instrument tracks often default to the inputs being All Inputs meaning both controllers will be merged and fed to both synths at once. Not what you want.
For separation make sure each Instrument input is set to the controller you want. All input sources will be listed in that input menu. Then they will both play separately. Of course you can record midi parts that way as well.
Users browsing this forum: Tacman7 and 113 guests
