Hey Guys. About to pull the trigger.
Wondering how yall set up your SSDs for sound library, operating and songs etc.
Thanks.
Coming from Reaper and hoping that this is as efficient. Very psyched.
by Vocalpoint on Wed Jan 12, 2022 8:38 am
avtzrovf wroteWondering how yall set up your SSDs for sound library, operating and songs etc.
Every DAW (windows) I have ever built has the same standard layout with 3 Drives:
1. C:\ (System) (in 2022 this will always be an NVMe SSD (usually Samsung EVO Series) minimum 500GB.
This drive is for the OS and apps installs and nothing else. I even do a custom redirect during OS install to ensure all documents, work files, downloads, images etc are on the M:\ drive...which is:
2. M:\ (Media) Like the system drive - this is always an NVMe SSD (usually Samsung EVO Series) minimum 500GB.
This drive is for all songs, voiceover projects, downloads, screencaps, scripts - everything that I use to support my work.
3. S:\ (Samples) Unlike the other two drives - I still do not see the value vs cost in making this one an SSD due to it's size. So I am currently using a Seagate Firecuda HDD - Minimum 2TB. Have not found any reason to think this is liability in terms of load time vs an SSD
This drive stores ALL my sounds, libraries (Like Kontakt, Toontrack, Spectrasonics etc) and every other sample based file I have ranging from old AKAI library images to one shots to Acid Loops to WAV libraries etc.
If you can load it into a sampler, a VSTi or use it in some sound design sort of way - it's here
Works for me!
Cheers
VP
DAW: Studio One Professional 5.4.1.66992 | Host Platform: Windows 10 21H2 | Motherboard: ASUS ProArt z490-Creator | CPU: Intel(R) Core(TM) i5-10600K | RAM: Corsair Vengeance LPX 32GB | Graphics: Intel UHD Graphics 630 (HDMI @ 1920 x 1080) | Audio Interface: RME UDX II (v1219) | OS Storage: Samsung 970 EVO Plus NVMe M2 (500GB) | Media Storage: Samsung 860 EVO SSD (500GB) | Sample Storage: Seagate FireCuda ST1000DX002 SSHD (1TB) | Monitoring: Presonus Monitor Station v2 + Presonus Eris 5 | MIDI Control: Native Instruments Komplete S61 & Presonus ATOM
by shanabit on Wed Jan 12, 2022 8:46 am
avtzrovf wroteHey Guys. About to pull the trigger.
Thanks.
1. SSD for OS, DAWS, all app installations, plug ins etc
2. SSD for my AUDIO. I create a folder for each Song so everything for a song is in one location
3. SSD for VST Library Data. SSD library, Piano library, Superior Drummer Libraries etc. ANY audio library goes here.
4. SSD for BKUP of the AUDIO drive
StudioOnePro 5.4.1
Apollo Twin Solo, Steinberg MR816X
OSX Monterey 12.2
iMac 2013, 3.5Ghz Quad-Core i7
32GB Ram, NVIDIA GTX 780M 4GB
*Im using a OCLP on an unsupported iMac
by Bub on Wed Jan 12, 2022 9:32 am
If you're using SSD's it really doesn't matter.
I have two SSD's because it was cheaper at the time to get two 250GB's rather than one 500GB but I wouldn't have a problem using just a single drive.
I just let everything install to it's default locations and have my songs go to my 2nd SSD.
That said, it's easier to backup samples and soundsets if you have them on their own drive that's not a system drive. It always gets difficult to backup and restore specific files and folders from your system drive unless you really know what you are doing.
Shane
Intel i7 6700k || 16GB RAM || 2 x 250GB SSD's || Win 10 Pro || Presonus Studio One Pro 5.5 || Studio 1810c || Yamaha HS-80M's || ART Pro VLA II Compressor || ART Pro MPA II Reference Series Mic Pre || Blue Bluebird Mic || The usual misc. guitars.
by davidlarson6 on Wed Jan 12, 2022 9:47 am
Win10 PC:
1TB SSD for OS, apps, etc.
500GB SSD for working projects
1TB External SSD for sample libraries
2TB HDD for archiving/backup
Macbook:
1 TB External SSD for sample libraries
Mac Mini Server with quick-swappable two-drive SATA enclosure for Backup/Archiving
DKLarson
Windows 10, i9, 64GB, 3X 1TB SSDs; Macbook Pro M1 Pro, 32GB, 1TB SSD
Audient iD14, Atom SQ, Akai MPK49, Ultranova, Moog Sub Phatty, Kawai MP11SE, Roli Seaboard.
by PreAl on Wed Jan 12, 2022 2:01 pm
Bub wroteIf you're using SSD's it really doesn't matter.
True to a point as there isn't really a bottleneck with the SSD itself. However there is a bottleneck with bus it's connected to, especially if it's SATA (but even a PCI bus) so you will get better performance with separate SSD's on separate busses, but the benefits of having separate SSD's are nowhere near the same as having separate hard drives, granted... I totally agree about file/folder housekeeping, it's definitely easier. I've actually got 3 SSD's but they have lots of partitions to make things easier manage (considering I'm running four operating systems on one computer it's essential for me).
Studio One Pro 5, Faderport Classic (1.45), Atom Pad, Atom SQ, Presonus Studio 26c, Focusrite Saffire Pro 40, Maschine Studio, Octapad SPD-30, Roland A300, Windows 10 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Intel i9 9900K, 32GB RAM,
EVGA Geforce 1070 (Nvidia drivers).
by avtzrovf on Thu Jan 13, 2022 3:01 pm
Cool. This makes sense.
So this is my first time really thinking about segmenting different things to their own HDs. I've only ever had a HD for Songs and a HD for operating and everything else.
A basic question about this fleshing out more of the process of it....
HD #1 - OS
HD #2 - Song files/audio
HD #3 - Samples
HD #1 - I use Reaper and I am looking hard at S1 (I have S1 Artist which I got with my Quantum). I'll presumably use both for now until Studio One takes over completely. I would install these on this drive along with Win 10,correct? What else goes on this drive? Plugins?
HD #2 - All song files and audio from projects goes here, correct? Just those....
HD #3 - If I was going to use Kontact as my sample platform. Would I install the program on the HD 1 and actual samples on this? Same for stand alone VSTs like from say EZD2 - Samples here, Program on HD1.
Sorry just trying to conceptualize.
by avtzrovf on Fri Jan 14, 2022 3:33 pm
As a seperate question, a sphere subscription only gets you notation and the "sharing" stuff?
Is notation a more robust sampler or is it only for writing and charts? I'm not sure sphere is worth it.
by Tacman7 on Fri Jan 14, 2022 5:52 pm
Sphere is a subscription. As a subscriber you get all that content and sharing etc.
You also get access to every piece of software PreSonus makes.
No software is different, what you buy, what you get with Sphere, both the same.
Studio OnePro5 Melodyne Studio
Kitchen Computer - Microkey Air Eris 3.5
Win10 Ryzen 5 3600 - Radeon RX 590 - 512GB SSD interface: Motu M2
Users browsing this forum: No registered users and 40 guests
cron
