...Selecting a midi note it turns white and once you have moved it or lengthened it it stays white and does not allow you to deselect it. This has happened on one note and also when moving a group of notes and appears to be random as in sometimes it does and sometimes it doesn't...
https://forums.presonus.com/viewtopic.php?p=272202#p272202
...this behavior still occurs
:: iMacPro
:: MacBook Pro M1 Max
:: Sonoma 14.4.1
:: Studio One 6.6.0
:: UAD Apollo 8 Ouad Thunderbolt (11.1.0)
:: StudioLive 16R Series III
by Quietly on Thu Oct 21, 2021 3:43 am
Someone suggested reinstalling S1 and it worked for me. Worth a try. Best,
Gerry
Those who can't dance always blame the band.
https://soundcloud.com/gerry-cooper-855281238
Windows 11 64 Bit, Installed Ram 16 GB, DDR4 3600 MHz, 11th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz
Not trying to hijack your topic, but I noticed other wierd stuff with midi notes as well since 5.4 and 5.4.1.
1, If you have a lot of instrument tracks (30+), select the midi events from all of them to have the notes from all tracks visible in the editor. Now, most VI libraries I use like it when I slightly overlap notes to create smooth legato's etc. If I view notes from many tracks at the same time, some times this slight overlap is just gone, and the note end looks quantized. I verify by selecting only the single midi event from a single track.. but, it looks fine there. Also playback is fine.
2. Same scenario as above with selecting notes from different tracks. But now I also notice that the editor doesnt follow the same color scheme anymore for midi notes, as I have defined for my tracks. Which is super annoying as I use color groups (i.e. shades of green are srtings, red is brass, etc.) to quickly identifiy instrument families.
On 5.3 this was fine.
Faderport 8 | Focusrite Scarlett 2i2 3rd gen
Studiologic SL88 Grand | Yamaha YDP-163 | Yamaha HS8 & HS8S | Austrian Audio Hi-X65 | Beyerdynamic DT770 PRO
Windows 10 x64 | AMD Ryzen 9 3900x | Asus X570PRO | 64GB G.Skill DDR4 3600MHz | 6TB NVME SSD
Can't say I have experienced this. Ever. Does this occur with only a single VI or different ones? Does it happen only when clicking notes, or also when using a midi controller / keyboard?
by maschinenwart on Sat Oct 23, 2021 12:35 am
it is independent of the instrument used.
it happens when moving or editing with the mouse.
:: iMacPro
:: Sonoma 14.4.1
:: Studio One 6.6.0
by stignielsen on Mon Nov 08, 2021 5:27 am
maschinenwart wroteit is independent of the instrument used.
This still happens to me, rather often.
I'm on studio one pro 5.4.1.66992 win x64.
by aleksandarristic on Tue Nov 30, 2021 4:23 am
This also happens to me. Quite often. The only way I found to de-select midi notes is to use my arrow keys on the keyboard, and just hold it until they all became unselected.
PC: CPU:i9700kf, Ram 32GB DDR4 Kingston HyperX, GPU: Nvidia GT730 2Gb, Audio Interface: RME BabyFace Pro FS, WIN 10 64bit, DAW Studio one v5
Users browsing this forum: Hommi and 67 guests
