Windows 10/64. Ryzen 3900x on a Asrock x570 creator. 32g RAM. Motu 828es > Ferrofish Pulse 16 AD/DA.
by WaterlooSunset on Fri May 22, 2020 7:00 pm
Sometime you need to do a refresh. On the bottom right on the S1 screen, click on Browse, then on home icon upper right and you will see a reindex button at the bottom.
Reminds me of a Hollies song, On a Carousel, Up Down Up Down .........
Anyways back to it ......
I assume you got it to save though, at least went through the motions?
You can right click on a preset as well and you should see a "show in explorer".
Win 10, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 4.something
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, BFD Eco GR5, TH3, Amplitube 4, Waves GR,
Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A
by johnboyd4 on Sat May 23, 2020 12:24 am
WaterlooSunset wroteSometime you need to do a refresh. On the bottom right on the S1 screen, click on Browse, then on home icon upper right and you will see a reindex button at the bottom.
You can right-click on a preset as well and you should see a "show in explorer".
Thanks for the reply. That didn't work though. It's weird. I can't get this song to save as a template either.I got a perfect drums note map to save one time. Then I tried making a different map and that wouldn't save. Now this SD3 map wont save either. I guess Im religated to always having some sort of issue.
I constantly have issues of one sort or another. I just switched to studio one from Reaper because I could not get it to stop crashing. I had a mac and then built two different PC's and all 3 crashed. I even got a new interface. Still didn't work. So I switched to S1 and its been running great except now these two problems pop up.
by Bbd on Sat May 23, 2020 2:15 am
Here are screen shots for my SD3 Drum Maps thru Studio One 4.X:
Here's a link to another topic that might help you:
viewtopic.php?f=151&t=33304
by johnboyd4 on Sat May 23, 2020 12:16 pm
Bbd wroteHere are screen shots for my SD3 Drum Maps thru Studio One 4.X:
Mine wont show up in the drop-down menu like that. Its really odd. I got my perfect drums map to show up one time and then it disappeared. Now I am having this issue. I contacted support.
by johnboyd4 on Sat May 23, 2020 12:21 pm
Here is a vid of the issue.
https://www.youtube.com/watch?v=Wgzxja0ghPE
by johnboyd4 on Sun May 24, 2020 3:59 am
Ok, well thx anyway guys.
by WaterlooSunset on Sun May 24, 2020 6:54 am
If none of this works, well..................... No idea, try on another machine to just see it work......
All i can say, this was an issue with me in 3.x something. I have not created any maps in a long while.
I had to re-index every time.
Verify you did re-index presets?
Also, my GM map is under the programs folder.
C:\Program Files\PreSonus\Studio One 4\Presets\User Presets\Pitch Names
My self created ones are under the Data folders.
E:\Studio One\Songs V4\Presets\User Presets\Pitch Names
by Bbd on Sun May 24, 2020 7:22 am
johnboyd4 wroteOk, well thx anyway guys.
I watched your video.
Your preset path in Explorer is not the same as mine.
Please review the screen shot I sent and compare to your S1 setup for presets.
by WaterlooSunset on Sun May 24, 2020 8:53 am
Hey Guys,
I just checked my main S1 PC. This is a new rebuild of OS from scratch last year so it is still pretty pristine IMHO.Also moved from win8.1 to Win 10 and a larger SSD for C drive.
There are 2 paths at play here. The only default pitchlist is GM which in on my C drive under this path.
My user created preset is save to this path, which is under where S1 points to to save songs/data.
F:\Studio One V4\Presets\User Presets\Pitch Names
I am curious if the OP looks in that place. His vid showed the default path for the single GM pitchlist.
I wonder if it is saving, just not showing up, (re-index).
Thnaks
Users browsing this forum: AriAhrendt and 21 guests
