Hello everybody!
Please find attached IDM 1.2.6 which is compatible with Studio One 4. Do NOT grab this version if you are still on S3 as it will not work correctly.
Rob.
Change: 1.2.6 is compatible with Studio One version 4.x
Change: Introduced a very small delay between preset changes to allow the previous change to take effect.
This should prevent the MSB value changing erroneously when selecting presets like a mad man :)
Change: Compiled for 64bit OS only.
Bug fix: If IDM terminated in a minimized state the last position and size was lost on restart.
IDM.v1.2.6 (S4 Only).rar
Instrument Definition Manager for Studio One 4.x
(385.04 KiB) Downloaded 83 times
by PreAl on Tue Jun 19, 2018 3:41 pm
Cool! Can't wait to try this.
by SoundWerx on Tue Jun 19, 2018 3:49 pm
Thanks. You may need to run this as administrator if you've got an OS > Windows 7 and have placed IDM in a location impacted by UAC.
by rlfint on Sun Aug 26, 2018 4:39 pm
HOW DO YOU INSTALL THIS?
by PreAl on Mon Aug 27, 2018 4:10 am
rlfint wroteHOW DO YOU INSTALL THIS?
Firstly press the CAPS LOCK button.
by peterbirch on Mon Aug 27, 2018 6:54 am
LOL... Sorry... lol
Digimax FS, 1818VSL
by SkylineUK on Wed Aug 29, 2018 2:18 am
Nice work Rob - needed more than ever since it's clear from V4 that MIDI and control of hardware modules in particular will never figure in Presonus's grand plan. It's all about EDM apparently, which is why I didn't upgrade. :|
My songs
Intel Sandy Bridge i7 2600 @ 3.4GHz, 4 cores, 8 threads, 16GB RAM.
OS & Programs drive: 240GB SSD
Data drive: 1 x 1TB drive RAID mirrored
Windows 10 Home build 17134
Studio One 64 bit. Version: 4.1.1.49941
Cakewalk by BandLab
1 Lava Lamp
by roland1 on Tue May 14, 2019 11:11 am
Haven't tried this yet, but thank you in advance. I still have a few keyboards/modules that could benefit from this.
I use: Studio One "Bug" Pro v4.51 & v3.56 on an i7 7700 win10 PC w16GB RAM and on a Mac Pro Tower (Sierra) w/RME & Focusrite interfaces.
When not loitering here, I can be found at: http://RolandK.ca
Attention all shoppers: deception and commerce are old friends. Ask questions; don't just nod and agree as expected.
[Unless it's "On sale" with a warning to "Hurry. Act now!" so you can also get a "FREE" [whatever] — what an awesome deal!]
by Lawrence on Tue May 14, 2019 11:51 am
Not to hijack the OP's thread nor dismiss his really great tool, but I built myself a patch manager extension for Studio One that uses Cubase definitions some long months ago. I'd forgotten all about it actually.
I don't use MIDI hardware synths very often so I did it more just to see if I could. I'll share it here at some point after I get back with Jeff (who has it and uses more midi hardware) to see how it's been working for him.
Or Jeff (if you're lurking) you can share it and explain it.
by roland1 on Tue May 14, 2019 4:47 pm
I enjoy seeing a bit of that mad-scientist programmer Reaper-like spirit seeping into this forum. :) Looking forward to seeing your instrument selection gizmo.
by Steve Carter on Wed May 15, 2019 2:12 pm
Here I go again - making a complete pillock of myself....
What's an ' Instrument Definition Manager' and do I need it?
(I'm presuming that my ignorance probably answers the do I need it part of the question i.e. most likely not, otherwise I'd know what it was!)
Be gentle with me - Regards....
by roland1 on Wed May 15, 2019 3:24 pm
The Instrument Definition Manager is a dictionary for non-musicians that tells you what each musical instrument does and how to contact people who may still play one of them.
[I'm just practicing my lying, in case I decide to get into politics. :D ]
It's an addon that allows you to scroll through the presets on an external MIDI module or keyboard. And, depending on if your interface has a LitterBolt™ connector, you can interface with your cat to make it purr on command. Most hit records now feature purring cats.
Steve Carter wroteHere I go again - making a complete pillock of myself....
by Jemusic on Wed May 15, 2019 6:15 pm
roland1 wrote It's an addon that allows you to scroll through the presets on an external MIDI module or keyboard.
From the serious part of roland1's answer yes this is what it does. It is for people who are using external synths and want to be able to see the presets from Studio One for any given hardware synth and be able to select sounds.
What it should do though as well is insert the correct midi program change and bank number into the track if this is to be really of any use.
There are issues with this though. There are many hardware synths out there form the 80's onwards so someone has to make the definitions in the first place. For every synth! Not sure on that.
The other option is you set them up yourself. I use hardware as well and what I have done is create tables of all the presets that are in my synths and also worked out the correct bank number and program change in order to bring them up. So I just look them up and then put the right things into the track header settings.
It still does not take into account sounds that you may move around and save into different positions or sounds that you create from scratch. I still say know what is in every one of your hardware synths. There is no getting around that.
And as the great Edgar Froese once said you should not be using factory presets anyway. Because the guy next door will have exactly the same sounds! Personally I think factory presets are fine. With something like a Yamaha Motif Rack ES there are just thousands of sounds in there and it is pretty easy to find the right one you are looking for.
by Steve Carter on Wed May 15, 2019 8:25 pm
Thanks guys...
Maybe I do need one - an IDM that is. If I'm understanding correctly, I have a lot of old midi song files that were written in combination with a Yamaha MU90 but, if the associated patch/timbre is not named in the midi file (or a patch change is invoked part-way through the song) I've no way, other than reliance on memory, of matching/assigning the original patch/timbre after loading the file into S1 - so an IDM would assist in this situation but I'd need to concoct this myself - where to start?
Regards....
by Jemusic on Wed May 15, 2019 9:16 pm
Well Steve you are in a bit of luck actually. The MU90 was a General Midi Module. In fact it was what they call an extended GM module. The MU90 was an XG model. What that means is that the first 128 patches for every GM module are all in fact the same. Every patch number corresponds to a certain sound or type of sound. (It is one of the great things about the whole GM concept)
XG means the patches go beyond the first 128 patches and although I am not over familiar with extended Midi modules, I am assuming that all extended patches will also be the same as well.
The Yamaha MU90 manual does not list the sounds but I have attached a document that does. What they do is use the standard program number along with Bank and Sub numbers to access the GX extra sounds. So if your midi files have used the GX extended sound bank then that info will be present in the program change data. You may need a midi event editor though in order to see them. e.g. Sonar etc.. Each track will have these programs set up to pull up the right sounds.
It is just a matter of finding out what the extra patches are. Your midi files will only have patch changes in them, you can still set up other hardware synths to play the right sounds. The end result often sounds nicer than standard GM modules.
GM GS XG MIDI instruments.pdf
(602.3 KiB) Downloaded 12 times
by Steve Carter on Fri May 17, 2019 3:43 pm
Thanks very much for that.
I do have a copy of the latest Sonar, which I got for free like many others I guess ( I also have an old copy of Sonar 2, on which the midi files were written and even Cakewalk from the stone-age) but I haven't got around to re-familiarising myself with it yet - perhaps it's time to make the effort.
Regards....
Users browsing this forum: Trucky and 17 guests
