Hi everyone!
I just bought a UVI Workstation but spent hours to add it on my DAW. I reset blacklist, reset VSTplugin folder, re-installed UVI (btw it works on its own correctly). Nothings changed. I can't see the UVI on the list in Studio One. I am fairly new in this industy so i am wondering if i am missing something too obvious? I don't even want to think that UVI Workstation is not usable with Studio One! If that so i'm gonna die right now cause i spent almost 6 hours to make it work. Thank you.
Computer: Windows 7 - i7 Q740 1.73Ghz 8GB RAM Tablet: The iPad (2017)
Mic: MXL 990 Interface: Presonus Audiobox iTwo Midi: Arturia Minilab Guitars: Fender Deluxe 72 Telecaster, Gretsch G5420, Seagull Artist Studio CW Deluxe QII Software: Studio One Artist 4, Ableton Live Lite, UVI Workstation, Analog Lab 3 Aim: Basically a singer&songwriter. Guitarist as a proffession. Recording ideas, covers, samples. Trying to do more. |
1) Add you specs in your sig please
2) You need the VST addon, purchased separately. Did you get this? https://answers.presonus.com/29541/studio-artist-require-rewire-support-for-third-party-plugins
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR, Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC. |
Since you reset the blacklist I presume you own the vst addon. Please make sure that the correct pad is added to the scanned folders. Could be your vst is not in one of the default locations.
Computer: Windows 10, i7-10700K, 16Gb mem, Studio One Pro 5.3 & Cubase Pro 10.5. Audio Interace: RME Babyface Pro FS, BOSS GT-001. Guitars: Blade RH4, Takamine GN51CE. Microphones: AKG C3000, Rode NT1A, Rode M3.
Band: http://www.idrismuziek.nl |
The following link might be interesting. You could try the solution at the bottom.
https://support.uvi.net/hc/en-us/articl ... -in-my-DAW Windows users: this may be the result of a VST cache issue. Create a sub-folder in your VST location, move the UVI Workstation plug-in DLL file there, then rescan your VST locations in Live preferences. After this you can move the DLL file back to its original location and rescan your VST locations if you’d like. Hope this helps...
Thank you guys for your answers.
@WaterlooSunset is right. I didn't know that i was needed the add-on. I'm a little disappointed though since i really liked Studio One Artist as it is very user friendly and easy to work with but is trash without that VST-AU add-on. I think i will use my UVI with Ableton and continue working with Studio One with the recorded file for a while.
Users browsing this forum: jazzundso and 32 guests
