exursion limiters
Posted: Sat Apr 18, 2015 8:43 pm
by Jeffmey
They are always on even at what i consider low volume level
Re: exursion limiters
Posted: Mon Apr 20, 2015 4:57 pm
by mwright137
Mine seemed like they were always on when mixing live music. It seemed compressed music (from my iTunes) didn't have the same problem. I stopped worrying about them.
Posted: Mon Apr 20, 2015 6:33 pm
by Jeffmey
I find the same thing mixing live music 16.4.2 2 two 312ai two 18sai two 328ai dose not seem to affect the mix just concerned may be pushing speakers to hard if this is the case they don't
seem to handle high volume to well
Posted: Thu Jul 09, 2015 5:18 am
by michael.kroeger
I had a gig last weekend and our sound technician had the excoursion limiter very often for not to say "always" on. The result was some smell and smoke out of a 328ai...
So I thought that should not happen through the voice coil temperature limiting.
The sound before was not extreme loud and it did not sound noisy limited.
Posted: Sat Dec 12, 2015 1:15 am
by fromnaija
michael.kroeger wroteI had a gig last weekend and our sound technician had the excoursion limiter very often for not to say "always" on. The result was some smell and smoke out of a 328ai...
Sorry to resurrect this thread but I was searching and just found something that happened to my 315AI. So, did your 328AI worked after it cooled down or did you have to repair it? What did they find wrong and how was it fixed? Thank you.
Posted: Sat Jan 09, 2016 12:47 pm
by michael.kroeger
Sorry for answering so late, i did not see your post...
the speaker had to be repaired!
the high-mid driver was blown and the amplifier module was defect!
Thanks to the warranty i did not have to pay anything, but it took 4-5 week to get the parts here in germany.
So i suggest to contact your local dealer/repair service.
Posted: Mon Feb 29, 2016 3:42 pm
by THDRMR
I just used my 328ai speakers for the first time a couple nights ago and I was experiencing the
same thing. The input levels were not hot at all but all of the excursion limiters were engaging
frequently. Is there any answer yet for why this happens?
Posted: Mon Feb 29, 2016 6:37 pm
by Finleyg
had the same problems with my ai subs end up replacing the drivers with Peavy Black Widows, the ai speakers to me are not design to do any live bands, at all, hope the ults are better, Waiting on feedback before I buy any of them
Posted: Sat Mar 05, 2016 7:40 pm
by martiynicolette
Finleyg...Did you replace with Black Widows to repair blown original speakers, or did you change out to fix the frequent excursion limiter problem? If it is the later case, did the Black Widows fix the problem? Also, which Black Widows did you get?
Posted: Wed Mar 09, 2016 6:29 pm
by Finleyg
It was done to replace the blown speakers but it solved the limiter problem as well, I now can drive the boxes full open with the output of my rm above 0 dbs and don't light up the limiter as often, and the spl output is higher than the orginal presonus drivers
Posted: Wed Mar 09, 2016 7:48 pm
by martiynicolette
Thanks for the info Finleyg. I haven't driven mine hard enough for a regular limiter kick in, although I've just used it for DJ.
I hope to get a chance to use it for live performances this summer. It's good to know that there is a solution should the limiter be a problem.
Posted: Sun Mar 27, 2016 11:15 am
by volksware
Finleyg wroteIt was done to replace the blown speakers but it solved the limiter problem as well, I now can drive the boxes full open with the output of my rm above 0 dbs and don't light up the limiter as often, and the spl output is higher than the orginal presonus drivers
Which model did you get?
