sub woofer aplication 18Sai
Posted: Mon Feb 23, 2015 6:49 pm
by passolutions
hi i would like to know if your subs were designed for outdoor applications , because i have purchased a pair of the subs but im not getting or feeling the presence of the sub at all when i set them up to use outdoors i mostly play heavy soca , and reggae music and im not getting that presence of that low frequency response at all indoors is extreemly great and i dont have a issue indoors but outside is where the problem is ................... what am i doing wrong
thanks for a speedy response
Re: sub woofer aplication 18Sai
Posted: Thu Feb 26, 2015 3:24 pm
by klarkkentster
Add more subs....
Sub to main ratio outdoor to indoor is completely different.
Posted: Thu Feb 26, 2015 8:59 pm
by passolutions
well if i use two yorkville ls 801 there is a huge diffrence with those far less if u use one of them outside so .......... is there a problem with the design of the presonus subs ........ just asking .....?
Posted: Fri Mar 06, 2015 1:38 pm
by dlovrien
The Yorkville LS801p is a horn-loaded sub and the 18sAI is ported (or vented). These have different characteristics. The 18sAI goes lower (29Hz vs. 45Hz for the Yorkville), but horn-loaded subs often give more "thump" when reproducing dance music. The LS801p (per specs) is louder (140 dB vs. 135 for the 18sAI) and uses more power (1500w vs. 1000w).
Ultimately it is a matter of preference depending on the type of music and the sound you want.
Posted: Mon Mar 09, 2015 6:29 am
by passolutions
all i hoped for ,is that the presonus sub would have been louder on th ouside thats all .inside its perfect no issues at all . just wanted to " feel" or at least hear the pressence of the sub on the outside .that is what i was expecting or hoped for
I honestly think that presonus should re design the 18sAi into a horn loaded sub or something like that . because using it as it is it cant perform as one would imagine or hope for when used on the outside . The tops are way too powerfull which i love but the subs needs to be applicable to indoor and outdoor applications
Posted: Mon Mar 09, 2015 2:39 pm
by mwright137
As mentioned earlier, outside you basically would use twice as many subs. You don't get the benefit the walls give you inside.
