Includes StudioLive 312Ai, 315Ai 328Ai and SL18sAi
Has anyone encountered this problem? I have followed the loading procedures exactly but the led's continally flash and never sync. I can't use the speaker and have had no luck with tech support. Is there a way of resetting the speaker to factory specs?
by martiynicolette on Wed Jan 14, 2015 10:41 pm
I loaded a new firmware version after I got my sub. It went smooth. I'm not sure which version it was, as it was back in September. When I get a chance I will check it out and get back with you.
by martiynicolette on Sun Jan 25, 2015 1:46 am
Here is my firmware info I promised you:
1.0.0.27052
Build May 8, 2014
So it looks like I do not have the most recent version. I'm not sure I want to load up the newer version if you are having these problems.
Did you get your unit to load up and operate normal?
by Warrior1 on Tue Feb 17, 2015 1:00 pm
I had to send the amp module in for repair....could never get it to load the firmware.....I haven't received the module back yet. I have two of the 18s Ai's and after having a problem with loading the firmware on the first one, I didn't try to update the other. It is working and I don't want to wait several months waiting for another repair.
