Since avb seems to be native on the ai/rm mixers in a near feature without using an optional card, what about the ai speakers?
Will the ai-speakers speak avb or do you still need dante cards to go digital?
The card that ships with the AI Speakers is basically just like the one in the StudioLive AI Mixers. It's for control only.
Our Dante Card for the speakers is available now. And we are working on an AVB Card that will come out later this year. |
Tnx!
tjdeerinck wroteGood news on the AVB Cards! Pretty sure you can do exactly that.
Hey, so the previous question got me thinking. I am running 315 and 18s per side. Can I just use the cards in the subs and connect the 315 with balanced cable from the sub?
Studiolive RM32AI, Studiolive 16.4.2AI, Studiolive CS18AI, Studiolive 32, Studiolive 32R, Studio One 3 Professional, 2 x Studiolive 315AI, 2 x Studiolive 18sAI, 2 x ULT15, 2 x ULT18, dbx DriveRack VENU360, 2 x Crown XTi6002, 4 x Crown XTi4000, 2 x Crown XLS2500, 2 x Carvin HD3000, 2 x Carvin LS1802, 2 x Yamaha SW118V, 4 x Yamaha S215V, 2 x Yamaha S115V, 4 x Yamaha SM15V, Windows 10 8gb, MacBook Pro 16gb, Waves Impact Server plus Diamond and Horizon plug-in bundles.
fromnaija wroteHey, so the previous question got me thinking. I am running 315 and 18s per side. Can I just use the cards in the subs and connect the 315 with balanced cable from the sub? mwright137 wrotetjdeerinck wroteGood news on the AVB Cards! It would be totally logical to run a single cat5 to a sub and link all the speakers in the same stack using the provided audio outputs, however it appears the design department at Presonus have a different idea of what is logical than the rest of us. A quick look at the block diagram for either the subs or the tops shows the analogue outputs are just mirrors/pass-throughs of the analogue inputs before the signal is digitised to be fed to the internal processing. The digital signal from the Dante card is another, separate input that goes directly to the processor with no means of converting to analogue. And with no second ethernet connection on the Dante cards for digital pass-through it's not possible to link speakers in any way. The official Presonus way to connect Dante speakers is to run a separate cat5/6 cable to each speaker from your central network switch, which is fine for stage monitors but a medium size rig with 2 subs and 2 tops on each side would need a bundle of 8 cat5 cables (and 8 Dante cards), instead of just 2 analogue... If you really want to connect your FOH with Dante then I suggest a cheap 4-5 way network switch permanently fixed to a sub on each stack so you can run a single cable from your gear to the first stack, then link across to the second stack and use short patch cables to connect each speaker. But it's a very expensive way of replacing 2 standard balanced cables. Another thing that's in the small print, which isn't made quite clear in all the sales hype, is that once you add the Dante card to a speaker you have NO CHOICE but to use it as it disables the WiFi connection. That's fine if you already use a hard wired connection for control, but if all you want to do is dump a speaker in a remote location with a long balanced analogue feed you CAN'T control it unless you also run a long cat5...
Karyn
rnaqvi wroteThe card that ships with the AI Speakers is basically just like the one in the StudioLive AI Mixers. It's for control only. It has been a year since you wrote that - any updates on the AVB cards? I have the RM mixers which has AVB built in - so would be easy just to use AVB which I assume will be cheaper than Dante cards. |
Bump! Any updates here?
________________________________________________________________________
Me: Live/studio drummer/percussionist, recording engineer, live sound, hardcore gear slut Studio: StudioLive RM32AI, StudioLive CS18AI, FireStudio Project x 2, Central Monitor Station Plus, Faderport, HP-60, Eris-8, PRM-1 PA: SL315AI (tops), SL18sAI (bottoms) Tools: Studio One Pro, Capture, SL Room Control, UC Surface, QMix-AI Computer: Mac Mini 2.6GHz 16GB w/256GB SSD, Lacie Thunderbolt 256GB SSD, iPad, iPhone Network: TP-LINK WR-1043ND, MOTU AVB Switch |
