Routing Effects to Aux outputs
Posted: Sat Apr 08, 2017 11:26 am
by brucegraham
Hi everyone;
New to this forum. Just purchased a 14.4.1AI & 24.4.2AI.
Looking to route, internally, the EFX returns to the aux's. I want to put Reverb & Delay on monitors.
Anyone know if this is possible?
Thanks from the newbie.
Bruce
Re: Routing Effects to Aux outputs
Posted: Sun Apr 09, 2017 7:00 pm
by Karyn
Welcome to the forum Bruce.
First.. Are you sure you have a 14.4.1AI ?
Next, this is the AI speaker section, not the AI mixers. You stand more chance of a mixer user seeing the post in the mixer section.
To route channels (including FX) to auxmix outputs..
Locate the control section for the aux channel you want to configure
Turn up the master level (for the aux, not the main master...)
press the "MIX" button (or "MIX/PAN" depending on which aux you're using)
the meters directly below now show the level setting for each channel feeding that aux.
the encoders (knobs) directly below each meter are used to set the level of each channel going to that aux.
Now the magic...
Press the "MIX" button a second time to access page 2.
the meters (and encoders) switch to the secondary set of channels like FX returns, Tape Input, Talkback. These are all marked on the surface near the meters.
