Is there a way to reset 315ai to factory settings?
Posted: Mon Apr 11, 2016 1:17 pm
by RichStudio
Still having issues with one of my 315ai. I posted about it earlier, so I won't drone on.
Is there a way to reset the speaker to the original factory settings?
My thought was to roll back to factory settings then re-try the firmware update.
Thanks,
Rich
Re: Is there a way to reset 315ai to factory settings?
Posted: Mon Apr 11, 2016 2:07 pm
by sjc193
http://support.presonus.com/entries/669 ... structionsThat is the best Info I could find on it, hope it helps, if you have recently updated the firmware via usb stick, go ahead and try it again, couldn't hurt
Steve
Posted: Mon Apr 11, 2016 2:11 pm
by RichStudio
Thanks Steve. I did all that. May mess with the speaker later today with an Ethernet cable connection.
Best,
Rich
Posted: Sat May 21, 2016 4:38 pm
by rpark
I had a similar issue with a firmware, and kept working at it (re-downloaded a fresh copy of the firmware, used different thumb drives, etc). The speaker (a 328) eventually came back to life and sounds fine now. I am not positive what I was doing wrong, or finally did right. Just keep at it, sometimes it takes a while.
Posted: Mon Sep 18, 2017 4:48 pm
by liviuvalentinpopa
how do I reset the presonus studiolive factory 315ai? I updated erroneously and all the lights were on and with a strange noise in the loudspeaker and no longer works-no more is heard than clicks I tried to update correctly after that but did not come back - please leave an urgent reply - thank you
