Two 328ai speakers on a single pole
Posted: Tue Feb 02, 2016 12:22 pm
by Dale Christenson
Is there an approved mounting solution to put two speakers on one tripod pole? I would like to put a pair per side and would like to use only one stand per side to keep it looking less "cluttered".
Re: Two 328ai speakers on a single pole
Posted: Wed Feb 03, 2016 4:51 am
by Karyn
I've not seen anything advertised. I'm not sure I'd want to balance two of those on a single tripod though, very top heavy...
If I HAD to do it... I'd prolly use a T bar and hang them from it...
Posted: Fri Feb 05, 2016 10:41 am
by dlovrien
This is such a thing as a Dual Mount Speaker Bracket, but not for speakers as heavy as a 328AI.
http://www.pssl.com/!S7XKb0xFCXh9BYnnxc ... er-Bracket (100 lbs. max)
The generally accepted way is to use two tripods - much safer. You can usually intertwine the legs a bit to take up the smallest amount of room.
Posted: Sat Feb 06, 2016 10:40 am
by rpark
You can also fly them, if you have something acceptable to fly them from and the right hardware. This can give a lot of options for directing coverage. Here's an example using a truss:
- Mounting option
Posted: Sat Feb 06, 2016 10:58 am
by rpark
You can do them horizontally too, if you need the dispersion that way (I would use three in a LCR sort of setup):
Just a few suggestions as food for thought...
Posted: Wed Aug 17, 2016 6:35 am
by matthewseymour
I've used the T-bar for speakers quite a few times, but even with light speakers doubling the weight on the tripod is really noticeable. The risk of over-balancing is significant....
