Includes StudioLive 312Ai, 315Ai 328Ai and SL18sAi
Is there an approved mounting solution to put two speakers on one tripod pole? I would like to put a pair per side and would like to use only one stand per side to keep it looking less "cluttered".
Sound 4-U! reinforcement and mobile recording serving Tulsa and surrounding areas.
Dale Christenson
StudioLive RM32ai
AVB switch
ULT15 x4
SL AI328 speakers x4
StudioLive 16.4.2 classic
Windows 8.1 SSD computer with UC, Surface, Capture2, and StudioOne2 Producer
by Karyn on Wed Feb 03, 2016 4:51 am
I've not seen anything advertised. I'm not sure I'd want to balance two of those on a single tripod though, very top heavy...
If I HAD to do it... I'd prolly use a T bar and hang them from it...
Sonar Platinum, Studio One.
Dante Level2 certified.
by dlovrien on Fri Feb 05, 2016 10:41 am
This is such a thing as a Dual Mount Speaker Bracket, but not for speakers as heavy as a 328AI.!S7XKb0xFCXh9BYnnxc ... er-Bracket (100 lbs. max)
The generally accepted way is to use two tripods - much safer. You can usually intertwine the legs a bit to take up the smallest amount of room.
by rpark on Sat Feb 06, 2016 10:40 am
You can also fly them, if you have something acceptable to fly them from and the right hardware. This can give a lot of options for directing coverage. Here's an example using a truss:
Mounting option
by rpark on Sat Feb 06, 2016 10:58 am
You can do them horizontally too, if you need the dispersion that way (I would use three in a LCR sort of setup):
Just a few suggestions as food for thought...
by matthewseymour on Wed Aug 17, 2016 6:35 am
I've used the T-bar for speakers quite a few times, but even with light speakers doubling the weight on the tripod is really noticeable. The risk of over-balancing is significant....
