I've placed an order for both the horizontal and vertical mounting yoke but dealers said that that item is out of stock till further notice.
Is there any replacement mounting yoke that I can order? Or do I need to wait for the official item to be made available? I have 2 328i white presonus AI loudspeakers waiting to be mounted but they've been sitting on the warehouse for a relatively long time. Please help presonus.. |
There is an accesories section on this web where Presonus actually sells items like that right off this web site straight from Presonus, might be worth taking a look at. (Haven't looked myself)
Steve
StudioLive RM32AI
Any good fabrication shop should be able to build you a couple of these brackets. If your still looking I can do a little investigation and see what I can find out...
I don't see anything for "brackets" as such for the Ai series speakers... just M10 mounting links which are 10mm load bearing loops... I did find on Amazon: http://www.amazon.com/gp/search/ref=sr_ ... B00CMEIC1G A LOT of speaker mounting hardware... like this for instance: http://www.amazon.com/Pyle-Pro-PSTND6-M ... s+brackets With a weight rating of 77 lbs, however, if your going to use a bottom mount 'pole' type mount that you should add a safety wire above, to prevent accidental failure from becoming A very BAD SITUATION!~
Tower:
Asus Crosshair V formula Z motherboard AMD FX9590 4.0 GHZ 8 CORE CPU 16GB 2400MHZ RAM CAS8 512 GB SSD PRIMARY HDD 1.5 TB THOSHIBA 128MB 7200 RPM DRIVE 2.0 TB WD BLACK 256 MB 7200 RPM DRIVE AMD R9-290 4GB VIDEO CARD Windows 7 P sp1 2006 Imac Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram Win7 Sp1 Mac 2006 Ipad 3, Ipad 4, Ipad Mini Iphone 6s+ Audiobox USB 1818VSL i2 Studiolive 2442Ai SL 16.4.2 X 2 Studio 1/3pro Sony Sound Forge 10 Engineer / producer Owner Twilite Zone productions Owner Studio G |
