Includes StudioLive 312Ai, 315Ai 328Ai and SL18sAi
I've placed an order for both the horizontal and vertical mounting yoke but dealers said that that item is out of stock till further notice.
Is there any replacement mounting yoke that I can order? Or do I need to wait for the official item to be made available?
I have 2 328i white presonus AI loudspeakers waiting to be mounted but they've been sitting on the warehouse for a relatively long time.
Please help presonus..
by sjc193 on Wed Sep 02, 2015 10:40 am
There is an accesories section on this web where Presonus actually sells items like that right off this web site straight from Presonus, might be worth taking a look at. (Haven't looked myself)
Steve
StudioLive RM32AI
ASUS RT-N66U Dual Band Router
4 EV ZLX-12P's, 1 TurboSound iX15, 2 Yamaha S115V's
1 Crest Pro-Lite 7.5 (7500 watts) amp, 2 Behringer EP4000 amps
10 58/57 mics, 1 SM86, 1 sE8, 1 sE2200, 1 AT2020, 2 AT2021
1 beta52 kick mic, 2 e609, 2 Radial J48 DI's, 1 PRO48 DI
2 4Bar lights, 1 4Play, 1 6Spot, 1 fog machine
by linuswee1 on Wed Sep 02, 2015 11:18 pm
Sadly the yoke mount isn't available on the store.. and also that I (in Singapore) cannot directly access it except to go through distributors... however it is through the distributor that they said that it is out of stock.
by lostinsound1 on Thu Sep 03, 2015 7:56 am
Is mounting it with the m10 mounting points (using eyebolts and galvanized aircraft cable) an option instead?
RM32AI | CS18AI | 24.4.2AI | Studio One v3 | Digimax FS | FaderPort | AudioBox iOne | HD7
by linuswee1 on Thu Sep 03, 2015 7:36 pm
Currently the church that I am in has false ceiling and hanging it isn't that much of an option.. I would rather mount it on the concrete beam instead.
by gadget69 on Sat Oct 03, 2015 9:55 am
Any good fabrication shop should be able to build you a couple of these brackets. If your still looking I can do a little investigation and see what I can find out...
I don't see anything for "brackets" as such for the Ai series speakers... just M10 mounting links which are 10mm load bearing loops...
I did find on Amazon:
http://www.amazon.com/gp/search/ref=sr_ ... B00CMEIC1G
A LOT of speaker mounting hardware... like this for instance:
http://www.amazon.com/Pyle-Pro-PSTND6-M ... s+brackets
With a weight rating of 77 lbs, however, if your going to use a bottom mount 'pole' type mount that you should add a safety wire above, to prevent accidental failure from becoming A very BAD SITUATION!~
Tower:
Asus Crosshair V formula Z motherboard
AMD FX9590 4.0 GHZ 8 CORE CPU
16GB 2400MHZ RAM CAS8
512 GB SSD PRIMARY HDD
1.5 TB THOSHIBA 128MB 7200 RPM DRIVE
2.0 TB WD BLACK 256 MB 7200 RPM DRIVE
AMD R9-290 4GB VIDEO CARD
Windows 7 P sp1
2006 Imac
Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram
Win7 Sp1
Mac 2006
Ipad 3,
Ipad 4,
Ipad Mini
Iphone 6s+
Audiobox USB
1818VSL
i2
Studiolive 2442Ai
SL 16.4.2 X 2
Studio 1/3pro
Sony Sound Forge 10
Engineer / producer
Owner Twilite Zone productions
Owner Studio G
