Hallo Studio One User,
die neue Version Studio One 6.2 ist ab sofort zum konstenlosen Download bereit. Freut euch auf eine Menge neue Features und Verbesserungen! Den offizielle Ankündigung findet ihr wie immer hier: viewtopic.php?f=151&t=51926 Viel Freude! Ari ____________________________________________ Version 6.2 Release Notes (July 18, 2023): New features and improvements: ● “PreSonus Sphere” renamed to “Studio One+” ● Arrangement and Editing o Auto Zoom in Arrangement and Editors o Independent editing of Takes on Layers o Additional tools on Layers (Eraser, Paint, Mute, and Bend Tool) o Move and copy ranges between Layers o Consolidated Takes and Layers menu o “No overlap” option applied to Events on Layers o Option to display Layer name for Tracks and Channels o Improved naming and numbering of Takes on Layers o Event FX context menu for Audio Events o Crossfades for selected ranges o Improved “Tape” time-stretch editing o Song End marker with Stop function o Scale Highlighting in Note Editor o Color Note Events by Scale o Distribute Lyrics to Notes in Score View o Stretch Part Automation when resizing Notes o Arrow Tool options for Note Editing o Modifier for temporary Split Tool o New “Event Editors” folder in Browser for ARA-enabled plug-ins ● Mixing o Copy FX plug-ins including automation o Linked Polarity buttons on stereo Channels o Disabling Folder Track disables linked Bus o Mute/Solo link between Folder Tracks and linked Busses o Search bar in "Add Insert" dialogs ● Macro Toolbar and Organizer o Link to assign keyboard shortcuts from Macro Organizer o Multiple sort options for Macro lists o Text search for filtering Macros by name o Consolidated Macro Toolbar settings menu ● General o [Studio One+] Extended live notifications for Community messages o Customization preset selector for additional smart templates o Edit channel assignment for multiple selected tracks simultaneously o Delete command with no event or range selected now deletes selected track(s) o Event badge on Folder Events is now shown when folder is collapsed o New option to disable Dropout Protection completely - not recommended for regular use o “Send MIDI Clock” option for hardware controllers o Added Sensel Morph and Expressive E Osmose devices o Additional presets for Ampire and Pedalboard The following issues have been fixed: ● [macOS] Random crash when trying to open the panner pop-up from context menu ● [Track Presets] Some Pitchlist presets are not restored properly ● [Windows] SoundCloud client freezes when uploading from the Project Page ● “Add Tracks” dialog audio output list order changes when the master and listen bus positions are reversed ● Applying crossfades for short ranges is not accurate ● Audio not playing back when switching time stretching mode in certain situations ● Can’t create custom folder in Browser under "Track Presets" ● Deleted Volume and Pan automation of a bus folder return after reopening song ● Drag and drop stomp effects from Ampire to Pedalboard does not transfer parameters ● Event playback drops out after transforming to rendered audio in certain situations ● Focus issue with certain user macros created in Studio One 5.x ● Inspector panel size is not remembered correctly ● Japanese translation errors ● Lyrics not syncing correctly with 2nd and 3rd notes in 1/8 Note Triplets ● Note event editing via numeric input not working below bar 1 ● Metronome routed to Main Out no longer enabled on Listen Bus by default ● Mono button on Main Out doesn't work when Listen Bus is active ● Plus symbol is shown when removing effect via drag&drop ● Ripple Edit on video track causes overlaps instead of swapped events ● Scripting error in Tascam Model 12 device ● Track/Channels are not muted when muting folder or bus ● User interface becomes unresponsive when FX Chain loads too long ● X-Trem presets can set Pan mode on mono track New commands: ● Edit - Toggle Note Audition ● Track - Layers follow Events ● Track - Unpack Last Take to Layer ● Track - Add Bus for Folder Track ● Track - Add VCA for Folder Track ● Track - Layer follows Events ● Zoom - Toggle Auto Zoom ● Zoom - Toggle Auto Zoom Full ● Zoom - Toggle Auto Zoom Horizontally ● Zoom - Toggle Auto Zoom Vertically ● Zoom - Zoom Full Vertically
was ist denn ein Auto-Zoom, und woher will der wissen, wie weit hinein oder heraus jemand etwas gezoomt haben möchte ? ...nee, eigentlich wollte ich eh was ganz anderes fragen: wann gibt es das Handbuch als PDF-Datei ? Allein schon,, weil ich in einer PDF die Schriftgröße für meine Ü50-Augen anpassen kann, fände ich das standardmäßig toll schöne Grüße ! |
Trotz angekündigtem Expressive E Osmose support funktioniert das alles noch nicht. Auf dem Facebook Osmose Forum hat bisher noch keiner eine Erfolgsmeldung gepostet.
Kontrolle von MPE -fähigen Softsynths via Osmose funktioniert gut. Das Problem ist anscheinend nicht das Aufnehmen der Midi/ MPE Daten in Studio One, aber wenn ich ich eine auf dem Osmose gespielte und in Studio One aufgenommene Performance wieder via Osmose Synth abspielen möchte, dann kommt da nur Garbage aus dem Osmose Audio Out raus. Fehlende Noten, und die paar die spielen sind abgehackt und das war’s dann schon. Funktioniert alles bisher einwandfrei in Ableton Live, kann deshalb nicht nur allein am Osmose liegen. Studio One, zumindest auf den ersten Blick, scheint auch alle Midi Daten die vom Osmose kommen korrekt aufzuzeichnen, nur von Studio One Midi wieder zurück zum Osmose Synth, das klappt aus irgendeinem Grund noch nicht….zumindest habe ich noch von keinem gehört, der das bisher hingekriegt hat. |
