Hallo Studio One Benutzer,
das erste Wartungsupdate nach dem Major-Update 6 ist nun verfügbar. Die Version 6.0.1 kann ab sofort und wie immer kostenlos heruntergeladen werden. Hier das offizielle Ankündigungsposting. viewtopic.php?f=151&t=49902 Viel Spaß mit den Verbesserungen! Gruß Ari ____________________________________________ Version 6.0.1 Release Notes (November 8, 2022): Improvements and additions: ● Added Studio One Prime and Demo Activation ● Updated remote control mappings for Autofilter ● Removed file size limitation for importing MIDI files ● Copy & Paste channel settings from one to multiple tracks The following issues have been fixed: ● [ATOM] Bank Mode should not disable Sample Control Mode ● [ATOM SQ] “Performance Monitor” command not displayed in User Mode ● [Audio Batch Converter] Preset subfolders not listed ● [Audio Batch Converter] Rack devices can no longer be rearranged via drag and drop ● [Compressor] Makeup Gain knob is initially disabled ● [Fader Flip] "Hide Unassigned Faders" hides assigned Faders ● [Import Song Data] Aux channels are not properly imported ● [Import Song Data] Instrument track channel assignment not restored ● [NI Kontakt] MIDI CC is not recorded ● [macOS] Application language resets to system language on update ● [macOS] Improper Track notes formatting ● [Mixer Scenes] Input channels are not recalled ● [Mixer Scenes] Only the first disabled plug-in is recalled ● [Pattern Editor] Bottom Pattern area triggers notes ● [Presence XT Editor] Loading a song which recalls .soundx files triggers import request of the samples used ● [Pro EQ³] Enabling bands doesn't always enable corresponding curves ● [Pro EQ³] Graphics issue in 6dB shelving mode ● [Pro EQ³] LLC does not work for specific audio settings ● [Pro EQ³] No latency compensation in High Quality mode ● [Pro EQ³] Side-chain FFT curve not displayed with high sample rates ● [Project Page] Text labels cut off for FFT mode, Slope, etc. ● [Record & Mix Template] All automatically imported tracks are named 'Spur 1' when language is German ● [Room Reverb] Default quality setting is ECO instead of HQ ● [Scratch Pads] Zooming and duplicating takes too much time ● [Show Page] Time signatures don’t follow when setlist items are moved ● [Softube Console 1] Touch automation not working reliably in certain cases ● [SoundCloud] Audio files downloaded with wrong filename extension ● [StudioLive DAW Mode] Scribble Strips don't display channel count correctly ● [Track Presets] Bus remapping by name should not be case-sensitive ● [Video] Export issue with HEVC codec ● [Video] Mute button will stop all audio output when using Windows Audio ● [Video] Player window close/maximize icons not visible at certain luminance settings ● Bouncing in a 64-bit float document generates 32-bit float audio files ● Cannot move folder regions unless the folder is open ● Channel Macro Controls XY-pad show/hide button missing ● Clip gain overrides the Arrow Tool action when "Disable events under automation envelopes" is turned off ● CMD+TAB may cause unwanted secondary Tool selection ● Converting files in Pool doesn't keep mono files mono ● Copying or moving folder bus track/s results in false automation data ● De-Esser behaves inconsistent at different sample rates ● Different result when saving vs. applying Track Presets with Bus ● Different results when quantizing single vs. multiple selected notes ● Duplicating Instrument Parts during playback may cause audio stuttering ● Editing automation not possible right after bouncing an instrument track ● Editing grouped audio tracks is not working correctly ● Editor key command (F2) may not work anymore when mixer got detached ● Empty Event FX insert has no drop zone in Inspector ● Empty folder in Browser disappears but shows up again on refresh ● Enharmonic is wrong when dragging chords from Instrument Track to Chord Track ● "Export Stems" of a mono track results in dual mono file when "Preserve mono tracks" is enabled ● Fade-out inside a crossfade is not played properly in certain cases ● FaderPort 8+16 loses connection when loading certain 3rd party plugins ● Humanize dialog sliders do not use exact values ● Importing with Spot function doesn't create tracks in between existing tracks ● In the track list, option+click is slower than using the key command “show/hide all tracks” ● Inserting Arranger Section creates two entries in history log ● Logarithmic fade-out handle cannot be accessed in a crossfade ● Long initial delay for dialog to appear when adding a new song ● Lyrics editor non-functional in Japanese version ● Macro Toolbar sub menu is too wide ● Markers are not visible on light background ● Merging notes may cause left-over lyrics events ● Mouse wheel action is inverted for Note Length in the Select Notes dialog ● Potential crash on applying Audio Bend when working with events across grouped tracks ● Potential realtime export error when performed right after offline export ● Potential artifacts when using Transpose feature on 48 KHz audio ● Pro EQ & Room Reverb crash at very high sample rates (768 KHz) ● Program Change sends duplicate messages ● Rearranging song with time signatures may cause long processing time ● Refresh option in Browser not working ● Stem export results in dual mono file export when it should be stereo ● Rename File in Pool does not remember "Rename Event" status ● Selecting all tracks is much slower with a macro compared to mouse action ● Setting program change value with mouse switches to bank change after maximum value ● Several settings not saved in template ● Snap not working with some Scratch Pads ● “Split at grid” and “Merge / dissolve audio part” take a very long time if audio contains Melodyne data ● Start Page Artist Profile section shows Loupe Tool for data entry ● Strip Silence "Close Threshold" value not updated when linked to "Open Threshold" ● Studio One v5 user templates do not appear in v6 ● Tab key not working on the 'New' window ● Template icons have bad contrast in default light theme ● Tempo and signature ignored on MIDI file import ● Time Scale tool doesn't work properly in certain cases ● Transforming Instrument Part to Audio Part changes Mute state ● Transposing Instrument Parts stops key-switch triggers when note events are used to switch ● Truncated audio after bouncing Audio Part containing chord data ● Unable to add automation nodes in certain cases ● Unchecking side-chain output resets routing to Main output ● Unexpected behavior of Ripple Edit in certain cases ● User avatar is rendered with poor quality ● Using "Zoom Full" command while focus is on Chord or Arranger Track may zoom out too far ● When editing notes with part automation on different tracks, automation is merged onto a single track ● When "Solo through listen bus" is enabled, soloing tracks doesn't isolate channels in the export stems dialog
